On/off not working
RX-1000 WHEN I PRESS ON/OFF I HEAR A TICK ONLY. BUT THE SISTEM IS'NT TURNING ON.
THANK YOU,
HILLAH
    President:
  • 2,110 Answers
You have to replace the ON/OFF switch...
Posted on Dec 08, 2008
Gpz 1000 not cranking! what could it be?
Only a few reasons.. if engine not turning over at all its seized motor, it could be a bent valve and stopping the piston from completing its full stroke. or a piston rod. If engine turns over and not starting it could be fuel, electrical, or carbies jets, or valve timing.
Hope this helps
Ken
Aug 14, 2014 | 1986 kawasaki GPz 1000 RX
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
My ac goes off and on again and a clicking sound on passanger side
sounds like a relay is dead...the clicking sound is the relay turning on and off again...like "tick, tick tick, tick"? there is a relay behind the plastic paneling but you would have to investigate to find out which one it is...just pull off the paneling where you hear the noise and follow it to the relay that is clicking...
Jun 10, 2012 | 1990 Nissan 300ZX
I cannot change the cartridges as yhe holder seems to be stuck
Welcome to FixYa!
Note: When removing and inserting back the print cartridges, you need to use a small amount of force because of its safety locks. Just be careful not use excessive force, it might damage your printer.
If your printer has Two Cartridge System with no latches, here's a proper way to remove and insert the print cartridge. Please refer to the image below.
1. Press down the tip of the print cartridge and pull it away. You will hear a "click/tick" sound while pressing it downwards.
2. Make sure to remove the protective cover of the print cartridge.
3. Slide in the new print cartridge in its holder.
4. Lock it by doing the figure #4 in the picture below. You will hear a "click/tick" sound which indicates that it is locked.
If your printer has Two Cartridge Systems with latches, here's how to do it.
1. Pull up the latch. You will hear a "click/tick" sound.
2. Pull away the print cartridge.
3. Make sure to remove the protective cover of the print cartridge.
4. Slide in the new print cartridge.
5. Close the latch. You will hear a "click/tick" sound.
Thank you for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP DeskJet 940c InkJet Printer
I hear some tick sounds in ups and the ups doesnt supports when there is a shutdown in power
hello
If the UPS does not support the system when there is a shut down in power it means your batteries are degraded.
you have to replace the battery of the UPS and it will be working fine then.
Thank you
Aug 06, 2009 | APC Smart-UPS 1000VA UPS System
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
RX700 Ink drip reset counter?
which buttons do I press when turning on my RX 700 after changing the ink pads which will reset ink drip counter? Thanks
Jun 02, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Ticking sound
Gm will tell you this is normal lifter noise if it from the top of the motor. It could be from the exhaust but you would hear it from under the car more. I do not care for the responce from GM but they say it is ok.
Mar 01, 2009 | 2003 GMC Envoy Xl
Yaesu FT-26 I got a Yaesu FT-26 that is used. The Problem by it is that its frequence between 140.000 and 148.000, i cant get lower or higher than, I cant even send or recieve anything!!! even when i press...
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Feb 23, 2009 | Vertex FNB-27SM,...
 Grubhead
Grubhead
