Question about Presto HeatDish Compact Heater
When it is in the off position it still comes on?
When I turn the switch to the off position the heat still comes on?
  • dell_bean Jan 19, 2009
    My heater worked well until this, the 3rd winter of operation. At some recent point the footlight turned off, but occasionally comes on with coaxing. More important, the temp control dial fails to control output; the unit seems to run full power all the time, and even when switch is turned to the OFF position.
Removed the 3 screws, the two wires to the heat control, then removed the 2 screws holding the heat control on.
Next, I cut one half off (length wise) the end of an emery board and filed the contacts down.
Now works perfect...
Posted on May 19, 2009
The previous post is correct that the heat selector switch is at fault. One more detail to look at is how solidly the shaft of the switch is secured to the control body. It is threaded into the control and travels up and down as the shaft is rotated, forcing a little ceramic rod to press on the contacts that carry the heavy current, changing the "on time" of the coil. That rod is made of that material to insulate the shaft electrically from the current being controlled so that you are not exposed to a hefty electric shock by touching the metal shaft. I have seen the threads of the shaft strip and cause the shaft to be pushed back upwards, allowing the contacts return to their normally closed state. Without that downward pressure the contacts just stay closed permanently and the heat stays on full until the heater is unplugged. Eventually the shaft will probably come out completely .
I have tried to find a tap of the appropriate sized to rethread the control, to no avail. It seems to be a special size used only by the Presto factory. In any case just replace the heat control. There are three screws to hold the plastic cover to the dish and two more holding the control to it's mounting bracket. The two terminals on the control will work properly electrically if you accidently reverse them when reassembling the unit but try to return them to their original positions to prevent straining of the wires.
Posted on Feb 21, 2009
  • dsull585 Oct 05, 2010
    Where can you buy the heat control??
  • 56 Answers
This is most likely a bad selector switch or the contacts inside the unit have been bent out of place. If you take the back cover off of the unit and look at the contacts they should not touch when the selector is in the off position and when you turn it on they should make contact. This is all of course as long as it is not minus 20 in your area.
Posted on Dec 27, 2008
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Missing heating of the water.
Could be:
· Clogged filtering plate.
· Defective heating element.
· Defective wiring (open circuit, leads
off place or loose).
· Defective electronic control board.
You have already changed all major electrical components energized during the heating phase. But do not forget that failures sometimes could be mechanical. For example: failure could be in hydraulic circuit of pressure switch, sometimes hydraulic circuit can lost air pressure. Another note would be that your dishwasher have NTC thermistor which every second gives information about temperature to electronic than electronic controlled heating element by a relay.
In order to heating element come under the voltage is necessary to fulfill a couple of requirements. Microswitch on the door in the closed position, the pressure switch in position 11-13 (full position , level of water) and the main switch is turned on.
24881895-svalokc2bmago0zdlfvpjh25-3-2.png Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
Heater control knob not working
If you can pull the knob off the heat and look inside to see if the knob is broken out. if not you may have a broken switch.
Jun 23, 2017 | Volvo 940 Cars & Trucks
Machine turns on but does not heat up.
look the main switch, if it is with 3 positions you have 2 ranges of work:
  1. one position with gas heating and all electricity working
  2. electrical heating engaged too
you only need to switch in required position
Feb 07, 2011 | Coffee Makers & Espresso Machines
When main switch to heater is turned on, only the flame comes on - no heat or blower. Have tried numerous times to reset by turning main switch off for five minutes, but still does not work. Any...
Does the fan come on when you turn the Fan to ON at the thermostate? If it does then it could be the blower board not turning the low speed blower tap on. Or the Fan & Limit switch not working. If the fan doesn't come on in the on position then the blower motor could be out or the run capacitor.
If the blower comes on it the ON position then you can run the heat with the fan in the ON position till you can get the heat relay looked at.
Dec 21, 2010 | Heating & Cooling
The heat only comes out of the dash and not the floor when turning the knob to the floor position.
if air only comes out dash no matter what position switch is in then there might be a leak in the vacume line at the intake.
Jan 06, 2010 | 2005 Chrysler Town & Country
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
Presto HeatDish Compact Heater Logo
456 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
