Question about Pioneer CDXP1280 Multi-Disc CD Player Receiver - 12 Disc Capacity
Pioneer CDXP1280 12 cd changer. Power to changer, no operation
I unplugged the changer and tested the power to the changer. One side of the wire was hot. Are both sides of the supply plug supposed to be hot? I have no operation of the changer. This would be the 3rd one in 3 yrs. Thanks
    Scholar:
  • 150 Answers
I Think there are 3 wires to a Pioneer changer??
+12V Battery ( Hot ) on all of the time
Switched +12v ( accessories, or switched by the radio only when it's on,
and Ground (Chassis Earth)
I think there was 2x orange and one black wire
Make sure that there is a good earth to the changer. Use a multimeter on ohms between a good earth point on the car and the cd changer or the black wire.
If you disconnect and reconnect all poer to the changer, you may hear the motors whirr for a short time as the mechanism resets, but cant be sure.
Hope that helps
Posted on Jan 07, 2010
I have a pioneer 6 Disc changer. Plug coming out of back has red wire black wire and orange wire.red is power black is ground. What is orange go to
Normally ORANGE IS the SWITCHED power +12 which must comes from the accessories circuit of the car. The Red is always connected to the +12 battery and is always ON.
Nov 12, 2011 | Pioneer Car Audio & Video
The power was interrupted and now it will not play threw the speakers
try unpluging it from the power cable and taking a digital volt meter and checking to make sure your getting 12 volts or more on the power cable and then check to see if your ground is good .
if you dont have voltage at the unit check fuses or the may have lost the ground move ground wire to new location.....
caraudioquestion@gmail.com for more help
Oct 29, 2010 | Pioneer CDX-FM1279 12-Disc CD Changer
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
I have a pioneer car stereo and it outputs power to the car speakers, but not the output jack. When I plug wires into the output jack and test them with a mulimeter, there is no power to them. Also, if I...
yes the rca's behind the radio are shot a power wire must of touched them.there is a small fuse inside the radio connected to the circuit board marked fu located and connected under the plugs in the radio. that must be replaced inorder to work. or if you want to cheat connect a grounding wire to the outside of the rca and it should work.
Sep 02, 2009 | Pioneer DEH-245 CD Changer
I need wiring diagram for pioneer deh p56
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this: Yellow: Constant +12VDC (memory) Red: key-switched +12VDC (accessory) Black: Ground Blue/white: amp remote or power antenna output Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative. Left front: white Right front: gray Left rear: green Right rear: violet
Jun 13, 2009 | Pioneer DEH-P56 CD Changer
Wiring diagram needed
The Pioneer website has both the OEM and Install Mauals in PDF format thast will solve your problems... I downloaded both earlier today...
Apr 01, 2009 | Pioneer CDX-FM677 6-Disc CD Changer
Hi I need to replace my electrical aireal on my poineer deh425
in line
+12V antenna wier (blue/wht)__________switch___________Antenna Power wire
Jan 11, 2009 | Pioneer DEH-425 CD Changer
Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Jan 21, 2007 | Pioneer DEH-425 CD Changer
Pioneer CDXP1280 Multi-Disc CD Player Receiver - 12 Disc Capacity Logo
109 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
