Question about LG MV-1444Y Microwave Oven
Inside of microwave stained from burned popcorn how do i clean it
Clean inside of micowave
    Genius:
  • 1,199 Answers
Use a mild cleanser like soft scrub with bleach!
Posted on Dec 10, 2008
Microwave popcorn
Could be your KitchenAid microwave only works with bagged popcorn.
Jan 22, 2014 | KitchenAid Microwave Ovens
How do I clean the inside of the microwave? It is
DO NOT use SOS pads! They are made of STEEL WOOL and will remove the protective finish inside the oven cavity. Without the protective coating, the microwave can arc internally and ruin the magnetron. Use the green scrub pads you find in the dish detergent section of your local grocery store. They are considered non-abrasive. Use the green scrub pads along with a non-abrasive cleaner such as Soft-Scrub or 409. Wipe clean with a fresh water and dry with a clean cloth.
Jan 30, 2010 | Sharp R-1505 Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
Last night while making popcorn, I smelled burning plastic. I shut the Microwave off and open the door to find the rack hooks melting. What would cause this to happen? Can I use the Microwave anymore?
Quite often this is due to greasy build up on the inside of the unit, there will also be a mica plate probally in the roof or close to the top of the uniton the inside sidewall, normally held in by one screw this should also be removed and cleaned. If the hooks are melted bad enough they will need to be replaced or just cleaned with soap and water.
Aug 21, 2009 | GE XL1800 1100 Watts Microwave Oven
My oven started arching with micowave popcorn (4 or 5 different times). Now it will not heat. No error messages on the screen and everything else works. Thanks Dennis M.
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
I would like to know how to clean the inside of my microwave,the wrong cup was put in,and it caught on fire ,and I can't get smoke stain out. Thank you,Molly Dickerson
The smoke stain is almost impossible to remove as smoke tends to get in the pigment of the paint.
If there's a burn smell, you can try simmering a lemon juice and water mixture for several minutes in the microwave. You can also set a plate of charcoal briquettes inside and leave the door closed overnight (DON'T turn the microwave on - just let it sit). Keep the charcoal inside when not using the microwave and it will absorb a lot of the odor.
Jul 17, 2008 | GE Microwave Ovens
Popcorn stain in Microwave
Uhhhmmm, paint? Inside a microwave? YUCK.... that would make food taste like paint.
The yellow stain from microwave able popcorn is most likely a permanant issue. I have heard of the vinegar water, bleach etc working, but never had it work for me.
I don't recommend you painting the inside of a microwave. Some paint is flammable. Almost all paints are toxic.
May 14, 2008 | GE JVM1650 1000 Watts Microwave Oven
LG MV-1444Y Microwave Oven Logo
137 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
