Eurovox ultra 2008 has lost almost all channels
  • 7 more comments
  • lowrys1 Dec 08, 2008
    My eurovox ultra 2008 model has lost nearly all channels , I have already tried a channel scan via the menu
    still nothing , help
    done a factory reset
  • lowrys1 Dec 09, 2008
    Ca anybodt tell me where I can download the instruction manual for the eurovox ultra
    I downloaded the program but I cannot open it , I am now giving up as it would be easier to hack into the pentagon than fix a eurovox ultra
    I would like like to thank everyone one who has tried to help with this problem , but so far the instructions i have received may as well be written in chinese , I just do not understand them , could anyone give me simple directions like starty with pressing menu , set up etc , I am not the brightest when it comes to electronics
    I am giving up unless anyone can tell me where to get a manual for this piece of ****
    still no good
    it simply says eurovox ultra , nothing else , no numbers , which you will probably find in the manual , everyone keeps telling me there is no such thing as the ultra model it must be the max v or whatever , well i am telling you I have seen the others and mine is different , i cannot tune it but I can read , look on ebay , they are called the eurovox ultra
  • 19,396 Answers
If the TV is new, just check the aerial cable, try doing auto tune with a replacement internal aerial.
If TV still do not find any channel with a replacement aerial, then call the number listed on the owner manual to get support, and arrange an eventual replacement.
Posted on Dec 09, 2008
  • Ginko
    Ginko Dec 09, 2008
    If the TV is new , how comes that you don't have the instruction manual.
    Eurovox have been recently acquired by euromax the brand is new , and the website and customer service is still not working in full.
    There are no manuals available for free download on the internet.
    As I told you, If the TV is new, just check the aerial cable, try doing auto tune with a replacement internal aerial.
    If
    President:
  • 2,110 Answers
Press Blue and select Tuxbox Commander or TuxCom, this is a file explorer like windows explorer.
Scroll down to var and press OK.
Scroll down to keys and press OK.
Scroll down to Keylist.txt (because i use the evocamd emulator) and press button 4 to edit.
Now carefully check the format of the keyfile, you need to change each line to reflect the new keys.
An example would be:
N 5401 00 123456789ABCDEF0 ; ROM7 AU Key Time Fri Mar 21 02:21:04 2008
This means it's a Nagravision key for provider 5401 (NTL), Key 00, Key code 123456789ABCDEF0 then the time and date of the update.
Usually, you only need to change 1 or 2 digits from the latest key loaded, so highlight that line and press OK.
Scroll across to the digit that needs changing and using the number keys like texting from your mobile, enter the new digit.
Press OK again to exit the editor and exit (or Home), select save when prompted, then exit and save again.
The last thing is to reboot the box and so long as you got the key correct and edited the correct keyfile, you should now be watching TV.
That's how i did mine but then i am using the evocamd emulator... if you use another you might have to edit SoftCam.Key
  • 4,806 Answers
Can you provide the model number please
regards
Posted on Dec 08, 2008
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    Hi, if its a dreambox 500T follow these instructions:
    1. Plug a network cable from your dreambox in to A) your router or B) your laptop/pc.
    2. Setup your IP on the Dreambox so that it fits into your network,
    usually DHCP is enabled on your router. But for pc to Laptop set your
    IP's 192.168.1.2 and 192.168.1.3.
    3. Download A) Filezilla or B) Dreambox Control Center. Ftp into your Dreambox using: Username : root Password: dreambox connect to your dreambox 192.168.1.3
    4. Open the txt file in the var/keys/ folder, you will see when your in the ftp.
    5. Copy in the new keylist.txt , save and exit.
    6. Reboot your Dreambox and Whalla!!
  • Lee Hodgson
    Hi
    to find the manual we need the real make and model number of the digi box please
  • 599 Answers
Be sure the source input is the antenna/cable/satelite and not reset to an input that is dead or not connected to service provider or airwaves...good luck
    Genius:
  • 1,142 Answers
Hard reset the unit that should bring back all the channels
  • 734 Answers
Please once reset all setting of your tv..and try again
  • 2 more comments
  • futureloginn
    futureloginn Dec 08, 2008
    Press Blue and select Tuxbox Commander or TuxCom, this is a file explorer like windows explorer.Scroll down to var and press OK.
  • futureloginn
    N 5C01 01 B58EA13E6FD7BDD2 ;ROM11 AU Key Time Fri Nov 28 09:58:12 2008N 5C01 00 85AF581A3696B6C9 ;ROM11 AU Key Time Fri Nov 28 09:58:12 2008
  • futureloginn
    When you get to select Keylist.txt you have to then select number 4 on the remote. Not OK/Open otherwise you get the blank screen.
    Once you select Number 4 you will be presented with the list of Keys.
    scroll up/down to correct line , select OK and it will be ready to edit.
    Select Yellow button to put in Uppercase mode and then use Left/Right arrow keys to move the cursor.
    Select save / reboot and you should be ok,
    ALso I have already done another change today as the was another key change about 1hr ok.
  • futureloginn
    futureloginn Dec 10, 2008
    When you get to select Keylist.txt you have to then select number 4 on the remote. Not OK/Open otherwise you get the blank screen.Once you select Number 4 you will be presented with the list of Keys.
    Sergeant:
  • 399 Answers
Try doing channel scan.by entering in to the menu..and did u changed any setting.
HAVE LOST MOVIE CHANNELS, ANYONE HAVE LATEST CODES TO BRING THEM BACK PLEASE N*L (SEPT 2010)
There have been no new codes for a long time (2008 i think)
The latest firmware can be downloaded from afterdawn or techkings.
If a full re scan does not get your channels back, Virgin has started to introduce Nagravision 3 in your area. This is being rolled out all over the country, there is no fix available, and from what i have read, there is not going to be any for this generation of eurovox/starview/digivox/arnet receivers
Sep 03, 2010 | StarTech.com StarView SV411K 4-port KVM...
Codes for 5401 on 1 March 2010 for Eurovox
can anyone tell me if they have lost channels i have lost about 10 or so thanks
Mar 01, 2010 | StarTech.com StarView SV211K 2-port KVM...
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost a lot of sky channels
sorry to say that all the eurovoxs are loosing chnls there does not seem to be a fix yet for them you will have to change box or hold on for another while sorry guys
Apr 09, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Lost most of channels with eurovox tx
i think the answer your looking for is on my profile.
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox Max V 2008 - needs new firmware flash (27 Nov 2008)
go to http://www.bigmaq.co.uk/ download the latest firmware its there ive seen it install that problem solved
Dec 04, 2008 | Audio Players & Recorders
I have eurovox max 2008
due to upgrade in the software of the eurovox and other recievers you will need to upgrade your box once you have done that power scan your box and it should be up and running.
Dec 01, 2008 | Audio Players & Recorders
Eurovox Max V 2008 Scrambled
hi can u help me to unsramble my eurovox max v 2008.
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
