Question about Samsung RS2534 Side by Side Refrigerator
Samsung fridge freezer mod no SRS2028 19.3 cu, ft
The water supply leeks from the front of the fridge and Ice supply area .Wounderd how to remove the section from the door. I can not see any screws to get the front off the door of the fridge.
  • 700 Answers
The water hose runs through the bottom hinge then to the dispenser. take the kick plate off of the unit and then check for leaks. theres a coupling down there that may be yoiur problem.
Posted on Dec 22, 2008
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Have a top freezer MOD # ET4WSKXSQ01.. SER#VSW3914735
The ice maker kit you need , is IM1 kit . This comes with an icemaker , tube , water valve and everything needed to install . Instructions are included .
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Kenmore freezer won't make ice. I can feel a
water supply must be checked first, constant flow to the area confirmed. compreesor running? does the system reach temp in other compartments? Isolate system from the electrical supply pull away from the wall and clean behined unit clean coils and fan blades.
check tube for water still connected and return unit power supply. let me know what you have temp in fridge and freezer if this unit is duo.
Jun 24, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice maker not working
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Samsung RS2534 Side by Side Refrigerator Logo
191 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
