Question about Xerox WorkCentre Pro 785 Plain Paper Laser Fax
Can't fax from my HP Laserjet m2727nf.
I am not getting a dial tone and therefore not able to fax. It worked yesterday and several weeks before. I tested another machine and it worked so the jack and phone line are functioning.
  • 239 Answers
On this machine make sure the phone line does work. Have the phone company to make the checks. They make more checks in the line and in there system.
If you can move the machine to that location use it there and see the results.
If the machine does in fact does not work, the modem can cause this type of problem, but also the main board can do it too. First I would replace the modem board, much cheaper. If that does not work, Replace the main board, but it will be very expensive.
Posted on Oct 17, 2009
    Genius:
  • 2,120 Answers
Check the phone line with a regular phone.
Make sure you are plugged into the LINE port of the fax.
Posted on Dec 09, 2008
Hp laserjet3015 when sending fax fax call report sez no dial tone
change from menu the dial tone go to link and see how to change dial tone HP Support document
Mar 13, 2014 | HP LaserJet 3015 All-In-One Printer
HP M272 in the control panel says Redial Pending. Cannot fax out but receive incoming faxes.
If you can receive faxes, then your phone line is good.
Try and send a fax to your cell phone or another phone.
You should get a message on the printer screen saying it's dialing and listen for the phone to ring.
And listen for the fax noises.
It's possible the fax module is bad.
Dec 06, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp m2727nf does not recognize incoming fax calls. problem occurs in switzerland with analog port on isdn line. research for problem with swisscom engineer shows, that m2727 works with isdn nt V1 - V3 and...
Hello walter727, could you find a solution to your problem? I have the exact same machine over ISDN in Switzerland. My ISDN line had some changes and the fax won't pick up calls anymore.
Oct 07, 2010 | HP Laserjet M2727nf Multifunction Printer
When sending fax, I get no dial tone, and the fax get cancelled. Thanks for your help.
Unplug the fax cable from the printer and plug the cable into a telephone. Do you get a dial tone?
If no, call the phone company after you try a different cable.
If yes, plug the wire back into the fax and call that number from a cell phone. If it rings and you get a msg on the printer console saying "incoming fax" , hang up and fax again. Did it ever work?
Aug 21, 2010 | HP LaserJet 3050 All-In-One Printer
Purchased yesterday HP LaserJet M2727nf. Everything works except it won't receive faxes. Philip Schwartz, Esq.
Make sure the display says Auto or Fax. It should not say Manual.
Also check to make sure your phone line is plugged into the "Line" port and not the EXT or Phone ports. These are the 2 most common issues with not receiving. Especially on new machines.
Aug 12, 2010 | HP Office Equipment & Supplies
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
How do i find the fax number assigned to the (HP LaserJet M2727nf MFP)
Call a cell phone from the fax machine..the number will appear on the cell phone as a caller ID
Jul 09, 2009 | HP Laserjet M2727nf Multifunction Printer
Dial tone in fax mode
Is the phone wire from the wall jack plugged into the slot in the back of the machine marked "line" and not "phone"?
Nov 14, 2007 | Lexmark X9350 All-In-One InkJet Printer
Xerox WorkCentre Pro 785 Plain Paper Laser Fax Logo
742 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
