Question about LG LDF6810 Built-in Dishwasher
Hi All, we have just bought and fitted a Hoover HEDS 668-80 Dishwasher. When we tried to run the first wash, the pre-wash and wash light both light up simultaneously. The instruction manual says this means, "longer inlet time", with the possible causes "Faucets is not opened". Could anyone help? Many Thanks. Lisa. :-)
  • Spotty909 Mar 14, 2009
    Hi, I have EXACTLY the same problem. Did you manage to solve? Very frustrating given its a new machine!
  • 332 Answers
You do not have enough water pressure,, either change the water supply or check the pressure in your house should ba about 70lbs, to work the unit properly,, you could also increase the water supply from 3/8 to 1/2 inch up to the connection of the unit
Posted on Jun 23, 2009
    Problem Solver:
  • 18 Answers
YES HONEST ABE CAN HELP.... WERE YOUR DISHWASHER CONNECTS TO THE WATER, TYPICALLY UNDER THE SINK MAKE SURE THIS VALVE IS OPENED ALL THE WAY, ( TURN IT COUNTER-CLOCKWISE...
Posted on Dec 29, 2009
Hoover Dishwsher DDY062 user manual
Hi Margaret,
Here's the manual in pdf.
Hope this helps.Thanks!
Dec 14, 2011 | Hoover 24 in. HD83M Free-standing...
What tray is what for a Hoover nextra washing machine?
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Methinks you could also do with a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 22, 2011 | Hoover Washing Machines
I have a hoover dishwasher and it starts pre wash cycle then wash light comes on and it beeps and stops
THE PROBLEM IS THE LITRE-COUNTER SWITCH AND IF YOU CUT THE PLUG OFF, SOLDER THE WIRES AND SEAL, IT WILL WORK AGAIN NO PROBLEM, ITS COTACTS THAT GET MOISTURE ON THEM. EVERYBODY THINKS ITS PCB OR PRESSURE SW BUT ITS DEFO NOT. I KNOW BECAUSE I WAS A HOOVER ENGINEER.
May 23, 2010 | Dishwashers
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Dec 06, 2009 | Hoover Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Flashing lights
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe & drain would be good. All lights flashing indicates you have a block somewhere.
Pl. rate me if helped............
May 30, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
LG LDF6810 Built-in Dishwasher Logo
395 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
