Question about Home
Hot water pressure in kitchen tap rubbish
No hot water pressure in kitchen but rest of house is ok, I removed a non.valve but no difference
  • Anonymous Feb 01, 2009
    i have the same problem
    my kitchen hot water tab run just a drops of water
    don`t know what to do
  • 145 Answers
Install a pump
Posted on Dec 12, 2008
How do i fix low flow on hot water on a kitchen faucet?
Have you found a solution yet? I'm having the same problem and I posted back on January 24th. I have yet to get a response so anything would be helpful. thank you. 4_30_2016_3_59_35_pm.png
Feb 21, 2016 | Plumbing
How can I increase the hot water pressure in my home?
Cold water pressure is what give you your hot water pressure so they should be equal but if you have a restriction on the hot side such as a valve not opening on the hot side or not opening all the way then you will have less pressure or the pipe work on the hot side is not proper. Hard to say but check the valve on top of the hot water heater
Aug 13, 2014 | Water Heaters
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
My Rinnai 24 will only start when I use the the hot water in the kitchen (which is closer to the heater). If I open any of the hot water taps in the bathroom it doesn't work.. I have to start the hot water...
Looks like your recirculation pump might be bad. If your opening a valve close enough to the heater and it comes on, It sounds like it's giving your pressure switch a false reading and allowing it to come one while the farther away you get, it is not enough line pressure to overcome the safety's of the heater.
Sep 28, 2010 | Heating & Cooling
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Home Logo
258 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
