Hi We have bought a l19h01ub hitachi tv for the wifes parents, took it to their home set it up , but they now get no signal input when they switch iton, we live about 85 miles away so can not get there daily, i need to know how to describe which button to press on the remote to get the tv back to aerial input, the tv is only connected to an aerial and nothing else / Thanks Bill
  • beeftech Dec 13, 2008
    I have the same problem with the same TV. Retuning will resolve it, but the same thing will happen again after a few hours. I've spoken (argued) with the 'TechGuys' at Dixons/currys who are adamant this is because I am not using an external area. They refuse to accept that a £12.99 Matsui free view box will work perfectly from the same aerial, or a £150 unbranded freeview TV that also works fine. If you wish to retune anyway, select Menu > 3rd option down > Auto Installation > Start > pin (0000) and it will take about 10 mins to scan for channels. I've done this a few times now and it will find 85 channels and display a great picture. Come back to it later and back to No Signal.
SOURCE: Harmony 520 Remote switching HDMI input on TV (Vizio GL42L)
Hey there -
I'm using a Vizio GV42LF and I seem to have fixed the problem.
I just worked with the settings, and actually used the Help feature on the remote which helps you sort out the input select issues; I was surprised, but the step by step, "Is the TV on...yes or no", "Is the TV on HDMI1...yes or no", actually fixed the issue.
Now I have volume control on the TV, and can select channels on the set top box, or switch to my HTPC and stereo etc.
The remote itself I find a little cheap; compared to the Vizio remote, it's amazing how hard you have to push the buttons. The Vizio has "soft" buttons whereas the Log. is HARD to press, BUT maybe this is good if you have a little one running around like a madman.
DC
Posted on Feb 07, 2008
welcomejee
  • 10594 Answers
SOURCE: HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Posted on Jul 29, 2008
SOURCE: I bought a "Living Solutions"
For the Item: Living Solutions Colossal 3-in-1 (606426)
Look in this link (it's the manual for the remote). It may help. Just copy the link to the address bar & download the file. It's a zip folder.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
Posted on Sep 24, 2008
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
  • 108 Answers
SOURCE: ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Posted on Jan 08, 2009
I have hitachi plasma 42 HDS 69 tv it's shows " No sync signal" so how to fix that at home?
Hiya!
If I understand your question, it seems that you'll need to go into the TVs 'input selection' part of the menu and try another input until you get a signal
Please let me know how it goes
Nov 20, 2016 | Hitachi Televison & Video
Hitachi 42hd69 won't switch inputs
Hi Try pulling the plug on the TV for a half hour. This may reset it.
Hope that work for you.
Apr 26, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Can you solve the problem of loosing all digital channels overnight on the L19H01UB television. Thanks Trevor.
Every time you shut down it may have arcing that zaps the memory of DTV stations. Just turn it on again might regain the list of stations. If not then scan the stations again in setup menu.
Oct 21, 2010 | Hitachi Televison & Video
No signal
hi, this message means that the tv is not getting a signal, what signal are you giving it ? cable, satellite, antenna ??? when you first turn on the tv it should say on the screen ch or v1 etc,. you could have a bad tuner or the set is not tuned to the proper input on the back of the tv, let me know what your input signal is & where on the back you have it connected, video-tek
Jun 05, 2009 | Hitachi 50FX30B 50" Rear Projection...
Hitachi 42 Plasma TV
Do the lines move at all, or are they static? Someone else had a similar problem, and a fix that might work for you was posted at:
http://www.fixya.com/support/t293678-plasmaa_tv_not_going
Aug 21, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Trouble regaining tv picture
It sounds as though the TV [video monitor {Hitachi}] is not set to an input that is sending a signal. Snow is the result.
Cycle through the inputs on the set with ALL devices ready to send signal.
If you have good access to the input area you should see all of the names and what is plugged into each.
Jul 27, 2008 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Getting TV and DVD player to work through VR-587
check behind tv to see which input is being used,
repeat above step for source and amp. some inputs are assignable on the amp press menu and go to input setup and see how its setup. you got this one good luck.
Chris B
PHTBA tech
Jan 26, 2008 | Denon AVR-587
Hitachi pd7200 42" plasma
unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
mark
Dec 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
