Question about EliteGroup 845GV-M3 Motherboard
Internal memory card reader plug on the MB?
I can not find where to plug in the internal memory card readers on the mother board. The CPU fan went out and I had to unplug many cables to remove and replace it and that is the only cable I can not tell where it originally went. Everything on the machine works perfect now with the exception of the built in memory card reader. It is a black flat plug with 4 wires (black, green, white and red). It is my kids machine and they already have worked around this by using an external memory card reader but it would be nice to fix it and I hate a puzzle that can not be solved. Any help is greatly appreciated. Thanks in advance!
The memory card reader that you have is most likely running on USB, therefore you will need to plug it in to one of the USB headers on your motherboard. They usually are made for 2 USB ports so the connector for USB is 2 rows, but yours is just flat so it will fit anyway.
The USB plug and cable on the motherboard kind of look like this:
http://www.windowsdevcenter.com/windows/2005/02/23/graphics/figure14.jpg
Posted on Dec 08, 2008
    Scholar:
  • 37 Answers
More than likely if you cant find it on the mother board it is on a Pci card.  Try looking at the different cards that are installed at a 90 angle from the motherboard.(they are plugged into the motherboard and when you look at the back of the computer you can see them as well)
If that doesnt work then post what kind of computer with what kind of mother board and i will figure out where it goes.
Hope this helps.
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
Probably not a fixable one, but here goes. I
Hopefully you know by now that the message wanted you to push on the card to eject it. The pictures you want to retrieve...are they on the card or the internal memory? You can easily download from the card using a simple card reader. If you've ruined the mother board circuit on the camera, then you probably can't retrieve the pics from the internal memory. In retrospect, you should never use the internal memory on a camera. It's too small to be of any use and it usually causes no end of troubles.
Dec 29, 2009 | Olympus FE-140 Digital Camera
Connecting a card reader to the mB
Most multi card readers are usb, but not the external kind that fits in the back of the motherboard, the internal kind.
If you look at the edges of the otherboard you will see three small blue connectors. Those are internal USB connectors, it should say next to them. Plug it in the correct way round (it will only go in one way) into any one of the three.
Dec 02, 2009 | ASUS P4PE/L (ASU49J) Motherboard
Propor place to plug in internal multi card reader
Most mother boards have an internal USB connector.
Have a read through *********** board manual it will describe all the connectors. If you don't have the manual you should be able to find it in the ASUS web site.
Also if you look really close at the Mother board and read the little white writing next to the connectors you may spot it.
I just took the lid of my pc to prove it can be done.
Mine is labled USB3 it has a block of 10 pins (male) and one is blank so it is really 9 pins. You mother board will be different to mine but have a look and see what you can find.
Sep 19, 2009 | ASUS M3N72-D nVidia nForce 750a SLI...
Trying too install 4in1 card reader
If its an internal card reader, you should install it in the PCI slot. If it's an external card reader you should plug the card reader into the USB port. I need to know the brand and model of the reader so that I can give you more precise instructions.
Sai.
Mar 01, 2009 | IBM Computers & Internet
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
EliteGroup 845GV-M3 Motherboard Logo
1,080 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
