Question about Belkin Computers & Internet
Mouse movement erratic with Mac Mini
I have a four-port Belkin USB KVMA, with three windows PC's and one Mac Mini. Mac is running Snow Leopard OS. Mouse works perfectly with all three PC's but movement is erratic - hard to position mouse pointer where I want it, on the Mac. Is there any way to correct this erratic behavior?
SOURCE: Erratic mouse/pointer behavior
I ended up calling IBM support (after many calls to them) and since the Tablet was still under warranty I sent it out for repair and they ended up replacing the planar card. Tablet was returned and I have had no further issues with the mouse.
Posted on Nov 08, 2007
rickyostrom
  • 274 Answers
SOURCE: MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Posted on Nov 25, 2008
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Posted on Dec 07, 2008
yooperbud
  • 8637 Answers
SOURCE: Wireless Gigaware 26-990 unable to connect
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
Sphynkter
  • 221 Answers
SOURCE: 2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
Posted on May 16, 2009
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
Belkin optical wireless mouse does not work after installation vista
Try a different usb port,some wireless devices only work on a high speed usb port.
Jun 20, 2012 | Belkin Mini Wireless Optical Mouse...
Can't run the belkin wireless keyboard and mouse with my version of windows
Unless you have Windows 95 or earlier, I don' think this is a Windows problem. It's either the wireless equipment (the wireless sending unit) or a software issue. It could also be that the USB port you are using is non-functional. Try a different port. Try reinstalling the software. Try the Belkin site for help.
Oct 15, 2011 | Belkin Wireless Keyboard/Optical Mouse...
My acer Aspire 57342 usb port seems broke. How do I get it fixed. I have an air card in the rear port but the front port I can't plug my mouse or printer into. Also another question are both usb...
BAD News.
Usually the USB Port is a part of the Mother Board on a PC and the replacement of the Mother Board is the only solution.
You can find them on the internet at Ebay and other locations. BUT it is very involved to replace.
If you have one good USB Port, Get an adapter that will allow multiple inputs.
Example:
http://www.staples.com/Staples-4-Port-USB-2.0-Hub/product_837531
http://www.amazon.com/Belkin-4-Port-Ultra-Mini-F5U407/dp/B000Q8UAWY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1311466822&sr=1-1
http://cgi.ebay.com/High-Speed-USB-2-0-4-Port-Hub-Splitter-Cable-Adapter-/280673924100?pt=LH_DefaultDomain_0&hash=item4159783404
Question 2. I do not know. On most PC's two are horizintal and two are vertical.
Jul 23, 2011 | Acer Computers & Internet
Broken Usb wireless optical mouse
Hi Joseph,
Are you working this mouse on windows XP? Have you tried another USB port and ensured that the USB ports are functioning within the device manager?
Ensure that you are testing using fresh batteries.
http://www.belkin.com/support/dl/P74749-A_F8E874_man.pdf
Nov 01, 2017 | Belkin F8E874 Mini Wireless Optical Mouse
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Jul 08, 2009 | Kensington PocketMouse 72214
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
www.kaiweitech.com
Nov 03, 2007 | Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
