Question about Rival 5865-W 6.5-Quart Slow Cooker
Front sticker fell off
The big sticker with the on, off, high, low buttons on it. So I need to see a close up to see which red light go's to what.
The temperature sticker is lost si don't know where high or low is can you halp me please
The far left position is "off"- next right position is low and next is "high".
If there are four positions the far right is "warm".
Off - Low - High - Warm
Mar 17, 2016 | Crock Pots & Slow Cookers
Why is all lights flashing on display but wont respond by pushing buttons.. keeps beeping??
Unplug it, wait 15min replug and start again..the lights should indicate the high and low temp long or short time , and then of course warmer ..sometime high and low as well
Good luck
Aug 14, 2014 | Crock Pots & Slow Cookers
My rival crock pot model 5865 sticker on the heating unit that tells you high/low etc. fell off and now I don't know which position is high or low? Can you help? Can I buy a replacement sticker? H
L to R Round Left Button- Low-High - Warm Two buttons over each other Top - time up, Bottom, Time down Most Right Button - OFF Lights Left - HIGH Center - KEEP WARM Right - LOW
Nov 09, 2012 | Rival 5865-W 6.5-Quart Slow Cooker
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
I have a Betty Crocker "In Style" slow cooker that I want to use it today for the first time, but I cannot find the users' manual. No matter what buttons I press, I cannot get it to "start". It will...
I have the same problem, no manual & have been unable to source one on the net. By cycling the power button ensure that the red light is flashing. This indicates that power is on. At least mine is heating up. The test will be if I can reduce the setting as the cooking progresses.
Oh for a cooker with a 3 position knob.
"Just because technology lets you do something, it's not a good reason for doing it"
Sep 06, 2010 | Betty Crocker Fiesta 3.5 QT
Ronson slow cooker don't know which is high or low
on setting 1 (low),the slow cooker can operate all day and night if required
when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
bianca
Jun 12, 2009 | Crock Pots & Slow Cookers
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
All the lights are flashing
My father-in-law just Fonzied this one after a day of us all trying to fix the crock pot.
Press the "High-Low-Warm" button REALLY HARD. It's worked for us twice now.
Oct 12, 2008 | Rival 38651-C 6-Quart
Rival 5865-W 6.5-Quart Slow Cooker Logo
44 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
