Question about Refrigerators
What does dual cooling mean? - Refrigerators
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Usually it refers to a product such as Sub Zero that actaully has two completely seperate cooling systems. There are two compressors, evaporators and fans.
Posted on Dec 08, 2008
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Transmission fluid in radiator
Your radiator is dual purpose - it cools the coolant AND the trans fluid. If you have tranny fluid in the radiator that can only mean there is an issue with the tranny cooling part and a new radiator is in order.
Hope this helps!
Nov 06, 2010 | 1996 Plymouth Grand Voyager
Maytacg dual cool refergeration
wherever you can access the condenser side closest to the fan is the best place because you want to blow compressed air through the coils from the side where the fan is located as that is the side where the air is sucked in through the coil assembly. you want to blow the dirt out in the opposite direction of the normal air flow through the coil fins.
Mar 13, 2010 | Maytag Energy Star Side by Side...
I bought a kawasaki dual cool keys keyboard and i need the instruction manual. where can i find it?
Bought a Kawasaki Dual Cool Keys keyboard and need the instructions
Jul 04, 2009 | kawasaki Toys
My reliant K is is constantly over-heating even after 10 minutes of running time. Is that a thermostat problem?
Reliants run very hot normally, but you are definitely having a cooling problem. More than likely your thermostat is stuck in the open position. The reliant comes with a 220 degree thermostat, and what that means is that it doesn't kick in until 220 degrees before your fan goes on to cool down the radiator. It is much better to switch to a 180 degree thermostat, which will kick in sooner to cool everything down. Your Reliant also came with a single core radiator, which is also part of the cooling problem on these cars. It is a far better idea to switch to a dual core radiator. Between the 180 thermostat and the dual core radiator, your cooling problems will be a thing of the past.
Peace,
Chief
May 25, 2009 | 1989 Plymouth Reliant
Lg ductless air conditioner is coming up with code ch 5
Communication between indoor PC and outdoor PC missed. Check that all connecting cables are good.
May 02, 2009 | LG Art Cool LA121CNP wall/window Air...
Dual cooling fridge feezer top part of fridge warmer than bottom
You're frosting up. Either the box is set too cold or you've got a moisture problem which requires a full defrost. The fan noise is the blades hitting ice. Leave the unit open and off for a day or more and then start with standard factory settings. Avoid open liquids and window shopping inside your fridge.
Feb 01, 2008 | Refrigerators
Refrigerators Logo
2,211 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
