Question about Akai PDP-5016H 50 in. HD-Ready Plasma Television
Akai power supply problem
I have an Akai Plasma Model#: PDP5006H. the power supply is dead like so many other Akai unit. Akai says they have no parts to support this 2 1/2 year old TV. Can you repair the power supply board?
studio4000@yahoo.com
  • jerricuda Feb 28, 2009
    pdp5006h wont turn on power light flashes orange.With back cover off starts to power up green lights come on clicks twice then thats it.
5 Suggested Answers
  • 5 Answers
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is jah2mil@hotmail.com
Posted on Apr 08, 2008
  • 298 Answers
SOURCE: help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Posted on Apr 16, 2008
SOURCE: Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Posted on Aug 05, 2008
  • 52 Answers
SOURCE: VIDEO BOARD
Your tv is going into an error protection mode upon startup. The problem is probably not the video board. When the tv starts, it checks with the cpu to confrim voltages, if a voltage is off or there is a short somwhere, it will prevent the tv from starting up by clicking the relays to power off the high voltage of the tv. The problem could be the power supply, zsus board or ysus. Its hard to say without opening up the back of the set and testing some stuff with the meter, but normally its just a shorted cap, worst case you blew out a fet.. But easy to find if you know what your looking for.
Posted on Aug 06, 2008
dsacco86
  • 1077 Answers
SOURCE: AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
Posted on Jul 20, 2009
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
AKAI PDP5006H Plasma tv
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
Jul 20, 2009 | Televison & Video
Akai
hi there,
you must told to your hubby to check for the continuity on the main power supply of the unit, there's a part that need to be Replaced Small Electros In Main Power Supply.
let me know.
Oct 05, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
I need to replace a Y substain modular on a PDP5006H Akai TV, but they dont manufacture the part anymore. How can i get this part?
i cant find that model anywhere is it a pdp5016h? if so they have in stock at shopjimmy.com
Sep 22, 2008 | Televison & Video
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
VIDEO BOARD
Jul 12, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Screen will not appear
You have just found out why the plasma sets are fading from the market.
Both of you may have a power supply problem. The PS in plasma TVs is more complex than in LCD sets and therefore more likely to fail.
Since Akai is so poor on product support, they may not even have parts since that set was made by Samsung who also doesn't want to hear anything about them (their site doesn't recognize the Akai model number), you may be out of luck.
In researching Akai, I find large number of folks who will not buy any Akai anythings again.
This kind of performance is unusual for a Japanese company.
Jul 04, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Help
For PDP4294LV use:
For PDP4294LV1 use:
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Open Questions:
See all Akai PDP-5016H 50 in. HD-Ready Plasma Television Questions
Akai PDP-5016H 50 in. HD-Ready Plasma Television Logo
537 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
