My laptop volume is so low,
I try some uption but still got problem ,do u got any idea ? I have a Toshiba M65 S909 Laptop I have had it for 3 years. When ever I play DVD's the volume is always low. When I play CD's or Wav's the the volume is OK. It doesn't matter what player I am using the Volume is always low. I have checked the setting and they are all turned up to max. Is this a hadware problem or is it a driver problem? Anyone else with the same problem?
John
jfire@starstream.net
  • vsper54 Jan 02, 2009
    it's not the player.  i have the same issue (toshiba satellite a75-s213).  i have the feeling it's a problem with the sound card or drivers.  i'm still looking for a fix though.
  • 50 Answers
Are the dvds copies or proper ones that you buy from a shop
Posted on Dec 08, 2008
  • vernando008 Dec 08, 2008
    If the DVDs are not copies then the problem is likely the dvd player.You could try and clean the optic lazer with a cd cleaner and see if that works,
Laptop screen has a 1" wide, white bar.
What is a screencard? I think they mean display driver, try uninstalling Display Adapter and then reinstalling sometime fixes problems.
Apr 08, 2014 | Toshiba Satellite M65-S909 Laptop...
Laptop screen has a 1" wide white bar
please try to call/contact Toshiba Tech Support to advice where to get the suitable Driver's Software, but check this link 1st,
http://support.toshiba.com/support/modelHome?freeText=1157633
this is a link for all support given by Toshiba for your laptop with the contact details so you can reach the Tech Support to help with the software issue.
- My Recommendation for you is to upgrade your System to Windows 7 which will help you also to avoid such an issue in the future as its auto Install Drivers even if its not available, it search for the software and install it for you as an update.
KR,
Nasr
Apr 08, 2014 | Toshiba Satellite M65-S809 Notebook
White 1 in. Bar running from top to bottom of screen
Plug in external monitor to see how that works. If it does same the issue is with your laptop. If it works fine the issue is with your laptop display that needs replacement.
Aug 31, 2017 | Toshiba Satellite M65-S909 (PSM60U02W021)...
My Toshiba Satellite M65-S809 Laptop will not turn on! However it turns on randomly sometimes when i toy around with it, but that happens rarely. I tried removing battery, and cable to take out the static,...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 18, 2011 | Toshiba Satellite M65-S809 Notebook
Beeping then shuts down.
Hi Speedport!
This isn't something as simple as a dead / broken / malfuctioning battery is it ? Try removing your battery, plugging the laptop into the mains and running it idle. The Bios update you found may have been a coincedence...
David
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba m65-s9092 satellite laptop locked with bios password
Remove the battery, and the memory cover (1 screw), and the memory module(s). Under the bottom memory module, there is a white sticker (the bigger sticker)... remove that, and there is a small copper lead labeled J2 that looks like two E's mated with each other, you need to short the E's to each other for about 30 seconds with something metal. Put at least one memory module back in, and the battery, and try booting. If it still has a password, try again for a little longer, or press a little harder with the metal object to ensure you are making a connection.
Nov 07, 2008 | Computers & Internet
just in the system tray icon i.e, time and volume icon is located at right side of the taskbar
double click on volume icon in that u will be having Wave option increase that one and volume option also then u should hear the sound properly
If it is not solved just explain it briefly so i can give one more solution for the problem
Aug 31, 2008 | Computers & Internet
Toshiba LAPTOP m65-s821 wont turned on
dear sir.
yes u have to do one thing first you can do yr laptop need to setup some physical settings if you know bout hardisk located then plug out and then on your laptop if laptop is working then turn off it and take battry of then plug harddisk in then re start yr laptop do same as RAM if u know how u unplug both device and be carefull... it's help u..:)
Thanks
please vote
jo_chinmay
Jul 07, 2008 | CMB T43 750 Notebook
Toshiba Satellite M65-S909 laptop will not start
Based on the problem you have described it could be one of many issues as to what is causing the problems. I know that answer doesn't help but need to be up front with you and not list all the possible issues. What I can tell you is that our company would be able to diagosis the problem once at our nationwide repair garage. If your interested in using our company check out our company website at www.LaptopGuy.com. Take a look at the testimonal section to see that we do quality work. I
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
293 people viewed this question
David Payne
David Payne
