Question about Husqvarna 22 Hp 46" Deck Yard Tractor
Mowing I accidently it teh concrete on teh side walk, which bent my blades. I bought new ones and replaced them. But when i mow, it seems like only one blade is cutting. I am afraid i did damage to something else. What could it be?
    Scholar:
  • 35 Answers
I did the same thing. I replace the belt that turns the blades. The pressure of the impact had stretched the belt and was slipping on the pully that engages the blades. Try that first and check the other belts for tension, wear and condition....Also make sure all springs are attached, not stretched, and in good shape...Hope this is helpful....Joe
Posted on Dec 21, 2008
I thought the drivers side blade had become loose, causing it to gouge into the lawn. I checked the blade rotation, and it seems that the blade 'shaft' is tweaked? Is this possible? The blade mounts tight...
It could be spindle or blade is bent. I would check blade first then spindle. This is not uncommon. Hitting a branch or something while mowing can bend one of these. Hope this helps. Good luck.
Aug 07, 2013 | Garden
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
Feb 23, 2013 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Have a 3 year old 6.75hp Craftsman SP mower. Hit a stump yesterday with the blade, which stopped the engine instantly. Started again without any problem but now no matter how clean it is underneath or how...
Some things to try:
Keep the mower on a smooth surface - concrete or asphalt - does it still clank & stall?
If it stalls on concrete, try loosening the gas cap.
Remove the plug, lift the mower and rotate the blade, is it or the motor shaft bent?
Gary
Jul 03, 2011 | Craftsman Garden
My father in laws mower is mowing low on one side. We pulled the blades off, and they don't appear to be bent. Seems to hang a little low on the left side, but can't figure out why. Model is a...
Take it to a level spot in the driveway and measure the deck height. On one side then the other. If the mower is a deck on a tractor setup, there should be adjustments to fine tune the height on either side. If it ia a walk behind and measures uneven, the only thing it can be is the wheels aren't raises/lowered evenly or one side has more wear than the other.
Jun 28, 2011 | Garden
I hit a rock while mowing and now the mower is vibratating badly? What do I need to Do?
You bent the blade. Therefore you need to by a new blade and install it.
Good Luck!!!!
Wayne
Jun 14, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Left side of mower fell into hole while mowing - blade does not rotate smoothly and when blade spinning at full speed makes loud rattling did i bend one of the prop shafts ?
yes, it is bent, the equilibrium has been thrown off balance, unless you can hammer it back straight, I suggest replacing the blade with a new one or have a machine shop press your old blade back into shape
Aug 15, 2009 | Swisher Finishing Trailmower - 44cutting...
Suddenly no compression on Toro walk behind
yes the shear pin will throw the timing off.check it anyway it might be ok but then again you ever know.check for fire coil should be at 010.from frywheel it might slip check compresstion anyway with gauge then valve gap need manual for this if ohv check pushrods this could make bad compresstion if one is bent.let me know want you find out ok
Jul 24, 2009 | Garden
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 22 Hp 46" Deck Yard Tractor Logo
169 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
