Question about Kenmore 24032\24036 Top Load Washer
My kenmore elite three speed washer sounds like it is in a bind
When my washing machine does not agitate or spinn correctly and sounds like it is in a bind while operating.
  • Anonymous Jan 09, 2009
    Drum will not spin and I hear a grinding type sound, suddenly after a couple years of solid performance
    Novelist:
  • 161 Answers
I have seen clothes get between the inner and outer tub and restrict movement during spin and wash. This will require removing the outside case, call a service tech on this one.
Posted on Jan 08, 2009
Kenmore elite washer model 110 won't empty water and spin
Does it agitate? If it does not then it maybe the coupler that connects the motor to the transmission. If you hear a clicking sound. This may be your problem.
May 21, 2014 | Kenmore Oasis Agitator 4.5 cu. ft....
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore Elite 22982 Squeaks during agitation
I'm pretty sure what you are hearing is the outer tub sliding on the bottom frame. There are three tub wear pads located around the top of the frame between the tub and the frame. Click on this http://www.partselect.com/PartDetail.aspx?Inventory=334620&SourceCode=8 these are the parts that I think you will need. You can click on the parts select home at the top right of the page and it will take you to their home page. There you can enter your complete model number and it will bring up diagrams of your machine . Once you find these part the diagrams willshow you where these parts go. Good luck.
Nov 24, 2009 | Kenmore 22982 Top Load Washer
Top load direct drive will not spinn, but pump water out.
COUPLING BETWEEN MOTOR AND TRANSMISSION IS SHEARED AND NEEDS REPLACED.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Kenmore 24032\24036 Top Load Washer Logo
66 people viewed this question
Sal De
fordexpert
Robert Rankin
