Question about DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
DeLonghi TRD0820ER 2 kw Dragon 3 Oil Filled Radiator I need to know how the timer and thermostat work or indeed a manual would be good
  • Anonymous Dec 14, 2008
    lost my manual, forgot how timer works, thanks
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: instruction manual
Here are the instructions: DRAGON HM3
If the model is different , download from:
Select your product, insert model and download instructions here
Posted on Nov 25, 2008
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Posted on Dec 19, 2008
SOURCE: actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Posted on Jan 20, 2009
  • 89 Answers
SOURCE: Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Posted on Nov 01, 2009
Delonghi dragon 3 not working beep
The appliance beep's to indicate a malfunction. My manual say's to contact the De'Longhi customer service.
May 20, 2014 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I would like to obtain a instruction manual for the DeLonghi Dragon 2 oil filled radiator. Do you have an address, phone number or place I can contact. Thank you,\r\nPeter Knight
If you live in the US, Call Delonghi Customer Support @ 800-322-3848.
If you live in Canada call 888-335-6644
If you love in Mexico call 800-711-8805
That should help you, Peter.
Apr 19, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Actual output on settings
1. 900 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater Logo
649 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
