Question about Cell Phones
Why doesn't the Motorola V3 not hold a charge very long? I have shut down everything I can think of, I have changed batteries, but if I talk on the phone for 10 or 15 minutes it has to be charged. Sometimes I have to charge it 3 times a day
  • gaitedtogo Dec 08, 2008
    The batteries are new and work great in my Pebl.
    Thanks
    I purchased 2 Razors V3, everything works on them and I really like them but they both have the same problem with holding a charge, when in use. When the battery gets low they just shut off. If I am not using them (have them turned off) they will hold a charge for several days. It seems like there may be something running in the back ground, when on, that drains the battery. The blue tooth is turned off, I have turned off everything I can find.
  • 492 Answers
Battery is old. They wear out over time and need to be replaced.
Posted on Dec 08, 2008
  • Sean Johnson
    Sean Johnson Dec 08, 2008
    Well then the phone has a board problem. More information helps us to better troubleshoot.
Phone has switched off and wont restart
try taking the battery out for 5 or 10 seconds then put battery back in. Hold the red power/end key down. If that doesn't work see if it will power on while charging.
Oct 30, 2012 | Motorola Mobility RAZR V3
Hi, I have a motorola V3xx and i have a problem with the battery life. I will charge it in full but then after a few hours the battery status goes from 6 to 4. after another hour (not using it) it goes to...
That definitely sounds like a battery problem to me. The battery is no longer holding a charge - there's very little chance that it's a hardware problem. New batteries can be quite pricey, especially if you buy them from your carrier. This website tends to have them fairly cheap - $13 for your battery. I would swap out the battery and your phone should be fine! http://www.batteries4less.com/motorola/razr-v3-v3 Alex
Jun 08, 2011 | Motorola Mobility RAZR V3
My phone doesn't charge. I don'y know what to do.
i think u r battery is damage u have to change u r battery.
Jun 28, 2009 | Motorola Mobility RAZR V3
Phone shuts down continuously. Help?
Sounds like a faulty battery there my friend, when plugged into the charger there is continuos charge running threw the battery/phone, but when u disconnect the charger it is using the power from the battery, which in theory says to me the battery isnt holding its charge :) thanks alot.
Apr 10, 2009 | Motorola Mobility RAZR V3
Phone goes off while talking
the solution to these change the battery
Nov 20, 2008 | Motorola Mobility RAZR V3
Motorola V3 keep shutting down
Try a new battery if that does not work then you should take the phone and have the firmware flash to correct this error.....take the phone to a mobile service center to have this done.
Oct 25, 2008 | Motorola Mobility RAZR V3
Razor v3 new battery charge problem
GUEST - replaced the battery if the phone still gets hot then you need to replaced the phone.
Eror08 - change the battery try that first
Jun 05, 2008 | Motorola Mobility RAZR V3
Phone shuts off during operation.
hi
im sure you have a batt prob...
have your batt replaced and im sure your prob is solved...
Oct 12, 2007 | Motorola Mobility RAZR V3
Phone shuts down during a charge
change the battery and if that does not work take the phone and have the service center reflash the firmware on the phone this method should correct it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
