Question about NetGear GS605 5x1000 Mbps Networking Switch
Router failed numerous times so i bought a netgear fs605 5 port switch to hard wire in a ps3 and my dell lap top. can only run one or the other. not both at the same time. what is wrong?
    Problem Solver:
  • 5 Answers
The FS605 is a switch, not a router. You can only run one device at at time because you only have one ip address. You need a router between the internet and your switch if you want to use more than one device at a time.
Posted on Dec 11, 2008
I need password for my netgear wgr614v7 to hook up lap top the lap top is an dell latitude
the default setting is open (no password required) if someone else changed it in the router you need to ask the person who changed it or reset your router and start over.
Feb 05, 2010 | NetGear WGR614 Wireless Router
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Ps3 problem on NetGear NETGEAR WNDR3300 - RangeMax Dual Band Wireless-N Router everytime we go through the easy set up it the test fails. we spent 3 hours last night trying to manually add the ip address...
if you are going wireless have you typed in the encryption to gain access to the router. in the setup of the ps3 does is ask for passphrase or encryption........ plus it seems it would want to search for available wireless connectivity.......but you may be going hardline with ethernet straight in to the ps3 then it should be almost an automatic type connection set up should be easy.....but the thing i have experienced is that not all modems are compatible with game stations...........there maybe a list of compatible modems for your system..... give me more info on how you are trying to acquire.....so i can further assist
Dec 28, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
I bought a netgear FS605 swtich and it doesn't work on the ps3.
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Feb 20, 2009 | NetGear FS605 - 5-Port 10/100 Network...
NETGEAR USB WPN 111 and linksys router problem reconfigure proble
check if the usb light on the modem is lid or not.
try to reinstall the usb drivers.
and visit http://www.aakashjain.com/General+Troubleshooting+Steps+If+Your+Internet+Is+Not+Connecting.aspx
here are the simple steps u can follow.
Feb 17, 2009 | NetGear Wireless-G USB Adapter...
Hello please can you help? I am having problems connecting my playstation 3 to the net. I go through the setup and it finds the wireless connection but then then tells me its unable to display web page. I...
im guessing you have done this already, but reset your router and modem and switch off your ps3 then boot everything up again and see if that works. if not then try connecting your ps3 directly to your modem (again switch it all off unplug ethernet cables wire it to ps3 and switch it all on again) try it a couple of times, if this works then you have a problem with you router and probably need to do port forwarding or contact sky
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Encore and netgear
ps3 and lap top not recognizing the router
Feb 07, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear GS605 5x1000 Mbps Networking Switch Logo
344 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
