Question about JVC TH-S3 System
JVC TH-S3 Home Cinema System
For some strange reason the dislay on the front panel has stopped working. Is there a button somewhere I should be pushing, or is there a fault with the equipment?
  • certela Aug 31, 2008
    On standby mode, when I start the machine it stop in a few second. Impossible to run it at all.
    Genius:
  • 1,074 Answers
Yes fatman your eeprom is faulty this ic conrols a lot of function on your set.have the set checked out by a tech.
Posted on Mar 19, 2007
Whirlpool oven does not work, it's parked out and now is reading F9 on the dislay panel, no buttons work but stove top works just fine
Oven does not work displaying F9 on the display
GE, Whirlpool, and other brands use this same code for this same issue (door latch fault). You might be able to just clean any grease/buildup from the latching hardware, but it's probably an issue with the mechanism, control board, or wiring between the two.
Oct 21, 2017 | Whirlpool Kitchen Ranges
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
Hi; Our washer displays "Control Panel
jazzbassic,
On the front of the unit is a control lock button, you will need to push and hold that button unit the control panel is unlocked. This should solve this problem. PS you may have pushed the control lock button when you either attempted to open door or just learned on panel, either way this does happen from time to time.
Jul 11, 2011 | KitchenAid KHWS01PMT Front Load Washer
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
Turntable won't turn
Look at the front panel, at the bottom, in the middle.
Identify the button labeled "Turntable On/Off".
Push it.
Slap yourself on the forehead.
Next time you fumble to turn of the light in the dark, push the right button.
Dec 05, 2009 | LG LMV1630ST Microwave Oven
There is no power on the unit although it is plugged into a live outlet.
Possibly you have a burned out control board or a burned out control panel. I had a similar problem. I changed the control board first and it ended up being the front control panel.
Nothing worked on the front panel. No lights came on and no beeping sound when you pushed any button. I should have done the front panel matrix test first in the manual. But the manual lead me to believe only one button or one light would fail. For some reason the whole front panel stopped working.
If you problem is the same. Do the matrix test on the front panel. If it checks out okay then it's your control board. I believe if the motor control board is the issue you would still see the front display working.
The fuse is on the motor control board. Do not try checking anything till you view the manual below.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Aug 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
System error on xerox 8560dn 09 038 46 8515
ink count sensor flags are stuck.verify the ink is correct and genuine and then reset the error by doing the following
1- turn the printer on
2- wait for the xerox logo to begin moving acroos the display
3- Before the logo is centered on the display (stops moving) press and hold the back and help buttons on the control panel.
4- Hold both buttons untill the display reads beginning service mode initialization.Release the buttons and the printer reboots into service mode with the Service Diagnostics menu dislayed
scroll untill you find function menu then click ok
scroll untill you find Clear ISC fault and press ok
click back several times and then reboot the machine.
Good luck and let me know.
May 07, 2009 | Xerox Phaser 8560MFP Laser Printer
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
JVC TH-S3 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
