Question about Dell 1600n All-In-One Laser Printer
Burn paper, and show open heat error - Dell 1600n All-In-One Laser Printer
    New Friend:
  • 35 Answers
It is most likly a problem with the Fuser. If you are under warranty contact Dell. If not, replace the printer. The cost of a fuser plus the labor to install it is usually more than the cost of a new printer. Plus that printer is end of life, so the part may not be available
Posted on Dec 30, 2008
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
Will not heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "Vx9JMZRRKrg" placeholder
Jan 08, 2010 | Estate Dryers
Not heating
We have a full video library on appliance repair video’s
Common faults -
You-Tube video "oYErKqR3LsY" placeholder (do not delete)
Jan 07, 2010 | Dryers
DRYER RUNS WILL NOT HEAT AND TIMER WILL NOT MOVE
This sounds like the timer is the fault but check these Common faults -
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Inglis IS8200 Dryer not producing heat.
Common faults -
You-Tube video "75l_AtpGkks" placeholder (do not delete)
Jan 02, 2010 | Dryers
Dryer elements are not heating up
this is the thermostats or the heater has blown. We have a full video library on appliance repair video’s
Common faults -
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Dec 31, 2009 | Hotpoint Dryers
How do i replace the heating eliment? frigidaire fde336res2
i don't know what model You have so i will give you this link appliance repair video’s
Common faults -
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
Dec 29, 2009 | Dryers
Sharp AR-M450 is showing error code ''H4-00''
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
64 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
