Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer not working
I've has the printer for almost a year and it worked just fine utill suddenly it kept beeping and had "check printer" onthe screen. I don't know what to check and i thought unplugging it and re-plugging would help, but it didn't. Please help! I don't know what to check on my printer and I've lifted the lever several time, but nothing works. Also, usually when i lift the lever, the ink-set will drag by, and i could change ink if i wanted to, but now it doesn't move anymore. Nothing happens anymore! Please Help anyway you can!!! THANK YOU, and Have A great Day! Tolani
  • 10 more comments
  • Anonymous Nov 06, 2007
    Canon mp390 printer not working .
    Alarm flashing , display show " check printer press set"
  • le4do Nov 06, 2007
    Canon mp390 printer not working. Alarm flashing
    Display shows"CHECK PRINTES PRESS SET"
  • ARCES330 Nov 26, 2007
    I have the same problem print head won't move and it makes some kind of sound like something is jammed.
  • Anonymous Dec 05, 2007
    i have the same problem. please help me with it if u can
  • RubenAlonzo Dec 08, 2007
    I have the exact same problem, i genuinely like this printer but now i cant use it, any help here please?
  • paisa82 Dec 11, 2007
    THANK YOU,
  • Tiffwill Dec 13, 2007
    I am having the same problem. I have not had problems with my printer for over 1.5 years but today it suddenly stopped working and continues to say Check Printer. I have tried everything but kicking it. Someone please help.
  • Anonymous Dec 31, 2007
    The same
    Same...
    Mom doesn't know how'd fix it.
    Help? T____T;;
  • Anonymous Apr 15, 2008
    have a check printer error, will not print
  • Terrio May 05, 2008
    My alarm light is on and the ink heads will not move it makes a clicking sounds as it is powering up or if you try to print it will keep clickingit's like the heads are trying to move but can't can you help thank....
Sorry,
I don't understand what is the solution offered by the user 'bumbo' for the issued posted by 'TOLA'
I have the same issue and would love to find a solution
I don't understand the 5 star rating if there is no solution.
thx
Ari
Posted on Nov 11, 2007
Hope it works now
Posted on Sep 25, 2007
    Genius:
  • 3,587 Answers
I'd recommend that you get some fresh drivers, as they can go corrupted over time...look here for that link
Posted on Mar 17, 2008
SOURCE:
Works but no beeps - how to fix?
Yes look at panel on one of buttons you should see *beep hold in till you hear it beep .
Oct 22, 2015 | Washing Machines
Epson Stylus Photo R280 general error The printer has worked fine for years. All of a sudden 'general error' starts coming up. I understand this to be something is jammed in it. When I turn it on...
Hi John
This is a problem with the Encoder sensor hence you need to clean it and make sure there is no Ink on it. The encoder sensor is the sensor which is at the back of the carriage where you can find a plastic strip.
By cleaning it the problem will be solved
Another senario
If the capping unit is having problem only then this error appears. Check and make sure the capping unit is working well.
(Capping unit is on the right side of the printer where the carraige is parked when it is turned off)
Sep 08, 2011 | Office Equipment & Supplies
My Canon iP90 has been working perfectly but now won't work at all. Nothing. Not a bleep. The green light's on and I've done all the utility checks and they're fine. I've tried turning...
Hi.
If you had done utility check and they are fine, had you try printing on a stand alone not using a computer. if you can print on a stand alone, there is no problem on the hardware side of the printer because u were able to print on a stand alone. you can focus now on the software side by uninstalling and re installing the driver of the printer and that should work.
Jun 10, 2011 | Canon PIXMA iP90 Mobile Printer
Carriage problem with grinding noise
Your printers carriage belt has gone loose you are required to change it. I'd advise you to send it to an expert because changing of a belt in your ink jet is not feasible with guidence through text messages.
Thankyou for using fixya free utility - Kindly rate my solution
Jun 27, 2009 | HP Deskjet 3845 InkJet Printer
6 long beeps Dell GX280
You may have some machines with the bad capacitor problem. Check out saome pictures from my web site at www.ccl-la.com/badcaps.htm Open your computers and see if you have any capacitors that look like the pictures. The Dell GX270's and the GX280's have the problem. There are several places on the internet that can repair your boards if you find that this is the problem. I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years providing PC and printer support/repair
Jun 20, 2009 | Dell Dimension 4300 PC Desktop
Both Red Lights Flash together green light off - no printing
Mine did that too but my power went out in the house.
So diconnected it and uninstalled ssc utility.
Then reinstalled.
Worked fine after that. Hope it works for you.
Dec 26, 2008 | Epson Stylus Photo R200 InkJet Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Paper won't feed
The paper is pulled in with rubber traction wheels on a rotating rod where the bottom of the paper sits in the loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use.
Aug 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
154 people viewed this question
Clive
Clive
old marine
old marine
