Question about Epson Stylus Photo R320 InkJet Printer
Epson r360 reset tool
Please can you email me the application to reset the sink pad counter.
  • chunk1985 Jan 03, 2009
    Il have this off you please can you send me your paypal address to chunk1985@hotmail.com cheers
  • chunk1985 Feb 03, 2009
    Is this the SSC Reset Utlility because if it is it doenst work with the r360 ?
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
How to reset Printer Epson R360?
R360 Inkpad/page counter Resetter
Call me and ask
entangled@bigstring.com
Sep 09, 2010 | Office Equipment & Supplies
Does any1 know how to reset the inkpad message on\...
You need a program,
Call me and ask
May 20, 2010 | Office Equipment & Supplies
Epson r360 inkpad reset
Call me and ask
Nov 08, 2009 | Epson Office Equipment & Supplies
Epson R360 service required
Reset waste ink counter. Use R360 adjusment. Find at indoreset.blogspot.com. Or contact me.
Jun 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Apr 14, 2009 | Epson Office Equipment & Supplies
EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
Aug 23, 2008 | Epson PictureMate (C11C556001) InkJet...
EPSON 360
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Feb 19, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R320 InkJet Printer Logo
1,917 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
