Question about Lexmark Z600 InkJet Printer
How do I clear an incomplete print operation?
Just replaced inks. Printer refuses to print. Have disconnected: usb, power supply and rebooted, all without success. Next tried to uninstall. Message reads: "Please wait until printer has finished printing and then uninstall.''
    Sergeant:
  • 236 Answers
Try clearing your spooler queue:
Delete the spool printer files loadTOCNode(2, 'resolution'); In safe mode, delete the spool printer files. To do this, start Microsoft Windows Explorer, and then delete all the files in the following folder (where C: is the drive where Windows XP is installed):
  • C:\Windows\System32\Spool\Printers
Posted on Dec 08, 2008
Printing
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 11, 2012 | Lexmark X Office Equipment & Supplies
The compuer is not connected
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
  4. Reboot computer.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Lexmark X-1290, will not Print ! I did rplaced the Color Ink #27 and the Black-Ink #17 and will not PRINT. Ihad this Printer for 4-years and did'nt have any problem till NOW. The scanner works but the...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X1290 All-In-One InkJet Printer
Printer will not print. Removed both print cartrages, replaced black only due to cost/need. Printer will still not print (sheet comes thru blank)
Make sure both color and black cartridges are installed in the printer. The printer requires all cartridges to have ink in them to continue printing.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
My printer will not print from the documents program
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark X5495 All-in-One &USB...
My Computer is connected to theLexmark X5470and suddenly refuses top print. I have tried unplugging and reinserting all the connections and rebooting. Noluck!
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6. Select your operating system, download and execute the file.
Aug 08, 2011 | Lexmark X5470 All-In-One InkJet Printer
When i gave print from doucment machine takes paper and give it as it as blank, solve my problem,
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge. NOTE: Depending on the printer, the estimated ink level indicators can vary in appearance. Examples of estimated ink level indicators c01867289.gif c01867290.gif
  7. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  8. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Restart the printer Restarting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer. NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the back of the printer. Figure 1: Disconnect the power cordc01869581.gif
  3. Disconnect the USB cable from the back of the printer. Figure 2: Disconnect the USB cablec01850063.gif
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 3: Reconnect the USB cablec01868577.gif
  6. Reconnect the power cord to the printer. Figure 4: Reconnect the power cordc01869582.gif
  7. Press the Power button (c01602202.gif ) to turn on the printer.
for more information see this page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&lc=en&dlc=hu&cc=hu&product=1138373#N46
i hoprt his helpful
thank you for using fixya
Feb 15, 2011 | HP Officejet 4355 All-In-One InkJet...
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Lexmark Z600 InkJet Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
