Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Security settings My security settings not matching my computer so I can not use the wireless ethernet feature on the router... I must hard line into it to work it....
  • 340 Answers
The usual fault is problems with the encryption setup.
Check the encryption key, both default transmit key plus the encryption key in you router in Wireless security.
And – if you have set the MAC filter, and forgot to put in the new MAC address.
/Teis -> helpful? Vote please
Posted on Dec 08, 2008
  • Teis Thomsen
    Teis Thomsen Dec 10, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why not????
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
Well it has no secruity and i can't put it on... How do i do it ?
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure MAC Access Control list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router, you must configure your wireless clients with the matching settings. Your wireless clients will not be able to connect to your network unless you configure matching settings.
  • It is recommended you enable these wireless security settings from a computer wired to the router.
    1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
    2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    4. Click Security under Wireless menu.
      1. Under Security, Select 64 bit WEP (or 128 bitWEP).
      2. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
      3. Apply the settings. Please write down the key - You will need it later to configure your wireless computers with the same key.
Mar 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Tip
General Router Setup
Look at smaller routers, often called broadband routers that enable two or more computers to share an Internet connection.Within a business or organization, you may need to connect multiple computers to the Internet, but also want to connect multiple private networks - and these are the types of functions a router is designed for.
Not all routers are created equal since their job will differ slightly from network to network. Additionally, you may look at a piece of hardware and not even realize it is a router. What defines a router is not its shape, color, size or manufacturer, but its job function of routing data packets between computers.Wireless broadband routers look much the same as a wired router, with the obvious exception of the antenna on top, and the lack of cable running from the PCs to the router when it is all set up. Creating a wireless network adds a bit more security concerns as opposed to wired networks, but wireless broadband routers do have extra levels of embedded security. Along with the features found in wired routers, wireless routers also provide features relevant to wireless security such as Wi-Fi Protected Access and wireless MAC Address filtering. Additionally, most wireless routers can be configured for "invisible mode" so that your wireless network cannot be scanned by outside wireless clients. Wireless routers will often include ports for Ethernet connections as well. For those unfamiliar with WIFI and how it works, it is important to note that choosing a wireless router may mean you need to beef up your Wi-Fi knowledge-base. After a wireless network is established, you may possibly need to spend more time on monitoring and security than one would with a wired LAN.Wired and wireless routers and the resulting network can claim pros and cons over each other, but they are somewhat equal overall in terms of function and performance. Both wired and wireless routers have high reliability and reasonably good security (without adding additional products). However -and this bears repeating - as we mentioned you may need to invest time in learning more about wireless security. Generally, going wired will be cheaper overall, but setting up the router and cabling in the computers is a bit more difficult than setting up the wireless network. Of course, mobility on a wired system is very limited while wireless offers outstanding mobility features.There's a lot of jargon associated with the wireless router you buy. In the previous section, we discussed what 802.11g was. The 802.11 is a common standard that helps devices talk to each other. The g is an improvement to the 802.11 standard. However, as of September 14th 2009, a new standard has finally been ratified, seven years after it was first put forward! The new standard is 802.11n. This newer standard offers faster and more reliable wireless signals. You have been able to get Draft N routers for some time now. But the ratification of the treaty by manufacturers means that a wireless adaptor bought from one company should work with another's routers, and vice versa. Another bit of jargon you'll see is MIMO. This stands for Multiple-Input Multiple-Output. Which does, of course, tell you nothing! But MIMO is a technology aimed at giving you a better range for your wireless signals, and can carry more data in those signals (throughput). But you need a wireless adaptor that supports the MIMO technology, if you buy a wireless router with the words MIMO on it.f you have a 3G connection, look out for MiFi. This is a way to share computers using a 3G connection, rather than a fixed line ADSL connection, or cable broadband. With a MiFi router you insert your SIM card into, and this connects to the internet, rather than your USB dongle. The router should then let you connect several computers to the Internet at once using wireless, ethernet, or both.Manufacturers like Linksys are making it easier to set up wireless routers. Look for an Installation CD, or a Quick setup option. At the very least, there should be some instructions to follow along with. If you have an ADSL broadband connection, then you'll want to buy a wireless router with a ADSL modem built in. (It will say this on the box.) The model below, for example, is Linksys WAG200G - Wireless-G ADSL Home Gateway:.If you don't have an ADSL connection, but have a cable broadband connection, then don't buy an ADSL wireless router. You want one that you can plug your modem in to. Look for any wireless router that DOESN'T have the words ADSL in the title.The modem you got from your ISP will probably be connected to your computer via an ethernet cable. Unfortunately, you can't just plug this in to your shiny new wireless router and expect it to work! When you plug your Ethernet cable in to your computer, you're plugging it in to an ethernet card. Your ethernet card has a unique address called a MAC address. Cable providers connect you via the MAC address of your ethernet card. Your new router will have a different MAC address. So if you plug your ethernet cable in to this, your provider won't know where you are, and you won't get any web pages!The good news is that there's something called MAC address spoofing. This is when the routerpretends to be your ethernet card.If you get a wireless router then the install process will take care of this for you. The process will be fairly painless. The bad news is that some routers expect you to do all this for yourself! The manual will then explain how to get the MAC address of your ethernet card, and how to enter this information in to the router. The wireless cable routers we've chosen on our recommended pages all have easy setup options for MAC address spoofing.Each router will have what's called Configuration pages. You access these through a browser like Internet Explorer or Firefox. These don't come from the Internet, though, so you don't need an active broadband connection to see them. In the configuration pages, you can do things like set your broadband username and password, set up wireless security, set up online gaming, see the current status of your connection, and a whole lot more besides.
To get in to the configuration pages, you need to be connected to your router. This can either be with the Network cable, or via your wireless adapter. Start up your browser, and enter the address for your router. These differ, but for the Linksys router it will be:http://192.168.1.1
You will then be asked for a username and password. Routers will have a default for both of these. For the Linksys, it's admin for the username and admin for the password. (Look in your manual for the router's address and default username and password.) Click OK and you'll be in to your configuration pages.If you can't see any configuration pages then the connection from your computer to the router is not working. So don't blame your ISP! Time to pour over those manuals! Another thing you may need to do in the config pages is to set up wireless security. If you don't have security switched on, anyone within range of your wireless router will be able to connect to it. There are two forms of security that most wireless routers use, WEP and WPA. What you are doing here is encrypting your signals with a key. With wireless security turned on, the router needs your key before it will allow any traffic through it. No key means no access.
WEP
Wired Equivalent Privacy. This is an older form of security and is not as safe as WPA. There are programs around that hackers can download to crack WEP. Once they have WEP cracking software, they may be able to gain access to your router and get a free ride on the Internet At the very least!
The WEP key, though, will be either 64 bits or 128 bits in length. (128 bits is 26 characters, and will be mixture of the numbers 0 to 9 and the letters A to F.) If you have a Livebox from Orange, for example, then it comes with WEP security. When setting up the router for a wireless connection, you have type out all 26 characters. Get one wrong and it won't connect!
WPA
Wi-Fi Protected Access. WPA security is really an update to WEP. It uses different and stronger encryption, and so is harder to crack. It's easier for you to set up, as well, because you just need to set up a short pass phrase instead of typing out 26 letters and numbers! You should use WPA and not WEPA lot of wireless routers don't have security turned on by default. Your configuration pages will allow you to turn it on, and there is usually a help menu which explain the various security settings.
on Jan 20, 2011 | Computers & Internet
I have a Linksys wireless-G 2.4 GHz router directly connected to my PC. I've just bought a MacBook Pro and want to go online via this router. The Macbook finds the router but cannot connect to...
The reason you cannot connect, is you have to match the settings from your router to Airport- usually it requires you setting the security on your router to a specific WPA2, Wep, or no security- invariably I have had trouble getting clients to get online with the WPA2 set to the either or setting- but set it to either public or private- they're online. Anyhow, in order to do that- you will need to log into your router- if you have a pc/mac hard wired into the linksys via ethernet, open a web browser window and go to 192.168.1.1- it would be under wireless security. Match the settings on your Macbook, you should be able to go wireless at that point. Another solution, depending on your internet service provider... is that the provider could share your system remotely and assist with getting you online wirelessly (I know for a fact that Verizon DSL Business does do this. )
Jan 01, 2011 | Linksys Wireless-G WRT54G Router
Security setting
wireless security
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Aug 12, 2010 | Dell TrueMobile 1184 Wireless Broadband...
I need to et my user name and logon domain i dont rmember them . i just got my lap top repaired and need to reconnect to my router
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
>If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port to restore the Router to factory settings.
>Please click on Wireless and click on Security to check the Security key for the Network.
>If the Router is reset to factory settings, then it is required to enable the Wireless feature under Wireless settings and enable the Security key.
Good Luck!!!
Jul 02, 2010 | NetGear WNR2000 Wireless Router
My computer has internet connection through the port on the back, but not through the router for wireless networking. All the connections from the modem to the router and further to the computer are...
So, just to confirm:
PC via ethernet has internet connection OK?
The router IP is 192.168.1.1
The PC ethernet IP is 192.168.1.n (n is not 1)
If you unplug the ethernet cable, you no longer have a connection.
If these are correct, did you previously have wireless internet working? If so, just reboot the router (unplug its power).
If not, you'll need to check the wireless settings in the router with those of your wireless network card, making sure you are using matching security settings (WPA-PSK, AES256, matching 'key').
To access the router, browse to http://192.168.1.1 (ensure your ethernet is plugged in). If you haven't changed from the default login details, you'll find them in the router manual.
May 16, 2010 | Linksys WRT120N Wireless Router
I have no security on my d-line dir-625 and want to add it. How?
Apr 22, 2010 | D-Link DIR-625 (790069292637) Wireless...
No internet connection Message Wireless
You need to connect your computer directly to your router through an ethernet cable. Then, you need to log into your router's configuration settings page (the webpage used to initially set up the router). Once you log onto it, go under the wireless security section, and there you should find the network key (might be know as passkey).
Mar 05, 2010 | Belkin (F5D7230-4) Router (587009)
I have a linksys WRT54G wireless router set-up. The problem is when I add the security features (to keep the neighbours from hijacking my signal) my son's MAC laptop and Play Station 3 won't work.
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Dec 10, 2009 | Linksys Wireless-G WRT54G Router
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
138 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
