Question about Konica Minolta magicolor 2300DL Laser Printer
IP Change I want to change the IP address, Subenet Mask, and Gateway number manually. Acording to the Menu Map, I can go through Menu Network and do this but the options aren't there. DHCP, BOOTP, HTTP, SNMP are there.
    Problem Solver:
  • 15 Answers
When you see DHCP and it asks you if you want to use it and you say no, it should prompt you for Manual settings. Try it
Posted on Feb 27, 2007
Configure ip adress to hp laserjet p3015
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Apr 28, 2011 | HP P3015 Laser Printer
How could i change the ip addres my hp 4015n ?
Configure the network product View or change network settings
1. Type the IP address into the address line of a Web browser to open the embedded Web server. 2. Click the Networking tab to obtain network information. You can change settings as needed.
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state.
Jan 14, 2011 | HP LaserJet P4015N Printer
Hi, I have two printer HP 4015n, I installed them on the same time in the same office (two month ago). They worked fine, but this morning all lights keep flashing ( both printer) and can't print. Any...
Thank you for contacting FixYa with your printer inquiry.
Sounds like both these network printers have lost connection to your router or failed to obtain an IP address after server maintenance or network upgrades.
Would suggest printing a configuration page on each of the printers and determine what the IP address is (If there is one) and see if other devices are in conflict. Power down your printers and reseat your Jetdirect Network Cards and confirm cable connections. Re-Power the printers and print configuration again to see if obtaining IP address.
Find out what IP address are to be assigned these printers and manually configure via embedded Web Server or at the printer control panel. Consult your manual or Follow these steps:
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state..
Hope this helps. Please keep us updated and remember to rate this answer.
Nov 22, 2010 | HP Laserjet P4015x Printer
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
I have a Dell Printer 5100cn it is tied into ten PC's through a router, no Server. The IP address keeps changing, and I can not figure out how to set it manually. The other Dell printers let me set-up...
Why do you need to set it manually? More than likely this is because of DHCP settings on the network which keep issuing a new IP address...anyways...here are the instructions....
To set the IP address, subnet mask, and gateway on the printer to match the printer settings page, perform the following steps:
  1. Press the Menu button.
  2. Press down%20arrow%203100cn.jpg until Configure appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  3. Press down%20arrow%203100cn.jpg until Network appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  4. Press down%20arrow%203100cn.jpg until TCP/IP appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press down%20arrow%203100cn.jpg until IPAddressSetup appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  6. Press down%20arrow%203100cn.jpg until Panel appears, and then press return%20arrow%203100cn.jpg.
  7. Press the Cancel button.
  8. Press down%20arrow%203100cn.jpg until IP Address appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
    The cursor is located at the first digit of the IP address.
  9. Press down%20arrow%203100cn.jpg to enter the numbers for the IP address.
  10. Press right%20arrow%203100cn.jpg.
    The cursor moves to the next 3 digits of the IP Address.
  11. Repeat steps 9 and 10 to enter all of the digits in the IP address, and then press return%20arrow%203100cn.jpg.
  12. Press the Cancel button.
  13. Press down%20arrow%203100cn.jpg until Subnet Mask appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg .
  14. Repeat steps 9 and 10 to set Subnet Mask, and then press return%20arrow%203100cn.jpg.
  15. Press the Cancel button.
  16. Press down%20arrow%203100cn.jpg until Gateway Address appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  17. Repeat steps 9 and 10 to set Gateway Address, and then press return%20arrow%203100cn.jpg.
  18. Turn off the printer, and then turn it on again.
Jul 20, 2009 | Dell Office Equipment & Supplies
I have Windows XP Pro, SP2, Office 2007, and an HP Photosmart C7280 off a wireless router. Printer scans OK but 9 times out of ten it can't see the PC. DHCP is "on" but printer IP address is sometimes Auto...
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
Jul 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Ps3 wont join network
i had a simsilar problem with my nintendo wii. i also have a mac and broadband ( but that doesn't matter). if you get into your wireless router by going to 192.168.1.254 in your safari browser. go to "wireless" settings. there is a channel selection (1-7) change it to 1. that should work. if not change to 2 etc.
Apr 15, 2007 | Sony Playstation 3 (PS3) Console
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
192 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
