Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Im running winds vista and the two admin accnt have been deleted by my son now all i can get is winds cannot access the specified device path or file you may not have the appropriate permissions to access the item access is denied (0x80070005)
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. You will probably need to set another one up. You will need to boot your system up in Safe Mode.
To do this, turn the system on and keep pressing the F8 key. This will bring you to the Advanced Settings menu. Choose Safe Mode. When the welcome screen loads, choose Administrator, and press enter. Now all you should need to do is to set up a new admin account from the Control Panel.
If this doesn't work. Go back into Safe Mode and use System Restore to take it back to an earlier state before the accounts were deleted. This can be found by right-clicking on My Computer and choosing Properties. Or it can also be found in Control Panel.
Let me know if these work
Tim
Posted on Dec 08, 2008
Windows cannot access specified device path or file you may not have the appropriate permissions
Is your account an "administrator" account? This is important in 7 as well as Vista.
Also, did you install whatever it was to an external drive? If so, Windows 7 is bad about changing drive letters of external hard disks every time you restart. If this is the case, click your start orb and right click on "Computer" then left click on "Manage."
In the left pane, there will be "Disk Management." Click on it and give it a second for everything to populate. There are a list of all your drives in the middle towards the bottom. You can right click in their partitions and left click "change drive letter." From there you can change them back to what they where before and things will start working again.
As far as permissions go, they're a pain if you change stuff over manually. But, there is an easy way if you know specifically what folder or file you need permissions to use:
Add Take Ownership to Explorer Right Click Menu in Win 7 8 or Vista
This will add a right click context item where you can seize permissions quick like. It's SUPER handy.
Mar 07, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
All Problems have ONE solution and that is: www.longPathTool.com Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
Windows cannot access the specified device path or file. You may not have appropriate permissions.What's annoying about this message is that sometimes it has nothing to do with permissions at all! Here's a couple of possible ways to fix it, depending on your system.
Note: First, restart your computer in Safe Mode (only XP and Vista) and see if you can open the file or programs in question. If so, it's not a "real" permission issue, it's a program or process on your computer that is giving the error.
The best solution that has worked for most people is to simply uninstall Internet Explorer enhanced security configuration.
Method 2 - Turn off anti-virus or firewall If you are having this issue in Windows XP or Windows Vista, then your problem is probably related to an actual permission issue.
Norton Internet 200X, Bitdefender, AVG anti-virus, Trend Micro 200X can all cause this problem. If you have any of these programs installed, make sure to disable them and test it you can run programs, open files, etc.
If so, then you'll have to either use a different program or find something on the Internet about to how to configure your software to not interact badly with Windows.
The same thing can also happen with an overly aggressive firewall. If you are running Comodo firewall or something similar (other than the basic Windows Firewall), then disable that also.
Method 3 - Unblock the file If neither of those two methods worked, the file may be blocked by Windows. Note that this is only for Windows Server 2003 and higher.
When you copy an EXE file from another computer to a Windows Server 2003 box, there is what is called a blocked property set on the file. This is due to the increased security on servers.
Right-click on the file and choose Properties. You'll see a button called Unblock at the bottom.
Method 4 - Real permissions issue Finally, you may actually have a permissions issue. In this case, make sure you are an Administrator or you are part of the Domain Admins group if you are in a domain.
Also, you can try right-clicking on the file and choose Run As. Then type in the Administrator credentials and try to run the file. If you are able to run it, that means you account is not setup properly or is not in the rightuser group.
Feb 09, 2014 | Microsoft Windows 7 Ultimate for PC
Windows cannot access specified device, path, or file... app perm
sounds to be a bug in the system
ensure the program is working, goto system restore and turn it off
turn back on again, this will remove all the old ones, they could have the bug in them,
create a restore point now, then download "combofix.exe"
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
run this
it gives a report when finished, the top section shows deletions, this is the stuff it found
Nov 12, 2009 | Dell OptiPlex GX260 PC Desktop
I am continually receiving an error message when I try to open Print Shop 22 - either Windows cannot access the specified device, path or file. You may not have the appropriate permission or Could not...
have there been any operating system changes ? like moving from xp to vista ? this would be a simple upgrade if that was the case , has your product id expired ? i'd go to the manufacturers site if none of the above has changed and see if they still support the software ?
Jul 12, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Password jam
hey,
There is a way by which you can login in into your administrator account..if i.e you have not put a password in your main admin accnt which comes during the OS setup
start the comp in safe mode.
go to control panel users..
you shud se the default admin accnt and your own admin accnt... simply change the password/ delete your admin accnt
now exit safe mode and reboot in normal ... recreate your admin accnt
For further assistance feel free to contact me on
kushalagarwal22@gmail.com
Cheers
Kushal
Sep 02, 2008 | Toshiba Satellite A105 Notebook
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Jun 16, 2008 | Acer Aspire 4315 Notebook
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
