Question about Brother IntelliFAX 4100 Laser Fax
Our brother intellifax 4100 does not pick up the paper. Is there a protocol to follow and or a repair kit etc??
  • 215 Answers
Make sure paper stopper in cassette is not pressed too tightly against the paper. common problem on these models. best to leave an 1/8" gap.
hth,
razors
Posted on Jan 28, 2009
The fax machine does not pick up paper from the tray
when the paper pick up roller is dirty, ( with the dust) the paper can not be loaded properly, to avoid this problem clean the pick up roller softly with alcohol, use a brush you msut touch the entire surface of the roller, do not forget the separation pad clean it,
Nov 09, 2010 | Brother IntelliFAX 4100 Laser Fax
Reciveing a papeer jam ussually on any fax with a
Try to clean the pick ADF with a piece of soft cloth wet with alcohol
Apr 06, 2010 | Brother IntelliFAX 4100 Laser Fax
BROTHER INTELLIFAX 4100
When we set the time on our fax it doesnt save the correct time, we set the time and it only stays for about a couple of days and it changes. Do you have any ideas for a solution.
Heather
Oct 31, 2008 | Brother IntelliFAX 4100 Laser Fax
The machine says it has a paper jam
Please check your sensor if they have dust or paper?
Clean your Sensor if working properly.
Sep 19, 2008 | Brother IntelliFAX 4100 Laser Fax
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 skips
check the paper size settings, that it is set to the same size as the actual paper
~50% chance of being a solution, cant do better
Jun 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
