Question about Zanussi Washing Machines
Zanussi ZWD 1252 W washer/dryer E20 warning comes on
The E20 warning continually comes on after a min or two, all drain hoses checked for blockage etc nothing found including drain pump which appears to be working ok. can you assist.
5 Suggested Answers
SOURCE: E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Posted on Jan 18, 2008
SOURCE: zanussi washer/dryer zwd1471s
E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
Posted on Apr 15, 2008
ginko
  • 19396 Answers
SOURCE: I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Posted on Oct 15, 2008
SOURCE: I am getting a Code E21 on Zanussi Washer Dryer ZWD 1271W. This is on the Dryer cycle everything else seems to work.
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
Posted on Apr 15, 2009
  • 15 Answers
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Just try putting your machine through a 95 degree wash. This may clear the build up in the pressure chamber.
Posted on Jan 12, 2010
Zanussi zwd 1260w won't drain, no apparent blockages
REMOVE POCKET BY TIPPING MAHINE BACKWARDS. I HAVE SEEN ****** STICKS TO TOYS JAMMED IN POCKET.
Jul 26, 2010 | Zanussi ZWD1260W Front Load All-in-One...
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Tumble dryer works for 10 mins then switches off and flashes E20....what does this mean?
E20 relates to a blockage in the pump check the filter and that the pump is free to turn there may also be aproblem on the drain pipe check this also
Apr 25, 2010 | Zanussi FJD1666W Front Load Washer
E20 keeps coming up on washing machine and wont drain
E20 is a code for the consumer only. Electrolux would determine this to be E23 most commonly. This is because there is a blockage in the filter, drain hose or plumbing
Mar 31, 2010 | Zanussi IZ161W Front Load Washer
I am getting a Code E20 on Zanussi Washer Dryer ZWD 1271W
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
I am getting a Code E21 on Zanussi Washer Dryer ZWD 1271W. This is on the Dryer cycle everything else seems to work. Thanks
Apr 15, 2009 | Washing Machines
No spin E20 alert on washer how can i fix?
E20 is saying that the water is not draining, locate and clean filter if washer has one, check pump and outlet hose for possible blockage, make sure drain hose is not trapped or restricted in any way.
Plz rate my solution.
Thanks.
Jan 21, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washer/dryer zwd1471s
Nov 30, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
191 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
