Question about White Sewing 1730 Mechanical Sewing Machine
Walking foot instruction!
I have recently purchased a walking foot for my machine and it did not come with any instruction. I can get it on, but as soon as I begin to sew the needle gets stuck. Is there anywhere I can get instruction on how to install and use a walking foot.
  • queenqee Mar 23, 2009
    I'm a relatively new quilter. I cannot figure out how to put the walking foot on my White sewing machine.
    queenqee@aol.com
5 Suggested Answers
  • 4 Answers
SOURCE: Attaching walking foot
you probably purchased the incorrect walking foot for your specific machine. check and make sure if you have a high shank or a low shank....the way to determine if you have a low-shank is to measure the screw from the plate and look at the distance if it is 5/8 then you have a low, any higher about 1in. then you have a high shank, so you would purchase a foot depending on your shank.
Posted on Apr 26, 2008
  • 14 Answers
SOURCE: do you have an illustration
You can get a pretty detailed instruction/manual here for the FY5318. http://www.feiyueusa.com/Manual/92966.pdf
The 92966 is the FY5318 sold through Harborfreight.com
Posted on Jul 08, 2008
Michaelle
  • 65 Answers
SOURCE: Walking Foot for Brother LS-1217
Beckster, it may simply be that the walking foot needs to be tweeked a bit, perhaps screwed in further, or less.
If that doesn't help ...
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
Posted on Jan 24, 2009
SewCreative
  • 15 Answers
SOURCE: sewing machine maintenance, walking foot & free-motion foot
Is this a Janome MemoryCraft 9000? (I ask because the models seem to get mixed up in the threads)
If so, you can more than likely find accessories for the MC9000 either on eBay, your local Janome dealer (you can find the closest one to you @ Janome's website using the "Dealer Locator" feature) or even ... SEARS!
Sears contracted Janome to make several of their sewing machines (I think Janome might still be the actual manufacturer, but aren't 100% sure) and so the parts are compatible. You can even use a Kenmore Memory Card with a Janome MC9000.
As for oiling, if it's the MC9000 (much like practically all newer models) they don't need oiling. Though sometimes, you can dab a teeny-tiny amount of oil on the bobbin case if it needs it.
Posted on Apr 15, 2009
wfservices
  • 260 Answers
SOURCE: Need instructions for putting a walking foot together
http://www.husqvarnaviking.com/us/2821_3079.htm
This is a link to husqvarna site for help..Hope this can help you. Wayne
Posted on Mar 21, 2010
Walking foot for Pfaff 2030
Not sure what your question is, but the following may be helpful:
Pfaff Tiptronic Sewing Machine with Walking Foot
There are multiple web sites and videos online that explain how to install and use a walking foot.
You can most likely find a walking foot for your machine by searching the internet for:
Make Model walking foot
or contact Sears, a sewing repair shop, or online sewing machine accessory vendor.
What is Walking Foot Sewing Tips for Beginners
How to Use Walking Foot Attachment Sewing Machine
http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx
Pfaff Sewing Feet SewingMachinesPlus com
Nov 27, 2016 | PfaFF Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
No motor sound with walking foot on Bernina 1031?
Keep in mind that that is not a walking foot... it's actually an even feed foot.
Approach your issue logically. Take the EF foot off and put your normal foot one. Does the sound return to normal?
If it does... keep in mind that your machine is exerting more effort to make the EF foot work. That can make a motor sound differently.
Mar 19, 2013 | Bernina Sewing Machines
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
Where can I purchase an instruction manual , walking foot & embroidery foot for a JANOME MEMORY CRAFT 4800 QC
try janome website for the walking & embroidery feet & manual
try these sites for manuals also
(pdf) manuals online.com
sewusa.com
sewingmanuals.com
mastersewusa.com
sewingmachineplus.com
homeappliance.manualsonline.com
Jul 19, 2010 | Janome Memory Craft 4800QC
Using a walking foot on my Necchi 3537
Hi JoEllen,
The walking foot replaces the normal pressure foot on your machine. There is a screw on the left-hand side of the pressure shaft that holds the ankle (if your Necchi uses snap-on feet) on the shaft. Loosen this screw until the pressure foot (or the pressure foot/ankle combination) comes off. Now slip the walking foot on where the other foot came off and tighten that screw. You're ready to go!
Robbie
Jun 05, 2010 | Necchi 3537 Mechanical Sewing Machine
Mar 13, 2010 | Husqvarna Viking 1
#50 walking foot instructions
The arm on the walking foot needs to be above the needle clamp to be lifted as the needle moves.
Sep 01, 2009 | Sewing Machines
Dec 01, 2008 | Brother LS-1217 Mechanical Sewing Machine
Stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Jul 25, 2008 | Brother CS6000i Computerized Sewing...
White Sewing 1730 Mechanical Sewing Machine Logo
774 people viewed this question
Top White Sewing Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
