Question about Dayton E50 Heater
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
AFTER REPLACING WHOLE KIT AND STILL WONT LIT UP AFTER SPARK, FUEL SPRAYING AND FAN WAS WORKING. ANY HELP?
  • 232 Answers
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Posted on Dec 08, 2008
My 2001 pontiac grand am gt wont start. its turning over just fine and acts like it wants to start but it doesnt. fuel pump was just replaced 4 months ago as well.
Does the vehicle have spark ? Do you know what that is an how to check for it ? Is there a SECURITY light lit on the instrument cluster ? If the vehicle has spark spray some carb. cleaner into the engine an see if it starts then .
Apr 16, 2017 | Pontiac Cars & Trucks
2001 Chevy caviler still fires yellow replaced coils still wont run or hit
No fuel ! Spray carburetor cleaner into the engine through the throttle body . SECURITY light lit ? Injectors firing ? Just replacing parts isn't the way , you have to test . If there is spark , yellow or not it's fuel related . Or engine crank , cam timing off . Some good videos on youtube .
May 30, 2016 | Cars & Trucks
2005 saturn relay wont start acts like its not getting fuel
Is the security light lit ? anti - theft system ! Try spraying carburetor cleaner into the engine through the throttle plate ,if it starts you have a fuel delivery problem . The fuel pump or the injectors are not be turned on . You should check to see if there is spark also ,pull a plug wire an hold it near metal on the engine somewhere an have a helper try an start the vehicle . No spark , you have a ignition problem . You could have a no spark problem an it would act the same as a not getting fuel problem .
May 27, 2016 | Saturn Cars & Trucks
Replaced battery, alternator,starter and my 02 intrepid won't stay running
Did you check fuel pressure ? Are there any lights lit on the dash , SECURITY . Does it have a good blue spark at plug wire end ? Spray some carburetor cleaner or starting fluid in to the throttle plate , hold it open an spray it in ! If it starts an runs you have a fuel problem , Is it losing spark ? crank sensor problem ? Rather then just replacing parts you should have taken it to a ASE certified repair shop , would have cost less then what you have already spent !
Jun 24, 2015 | Cars & Trucks
Troybuilt tb80ec wont start
If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
It stalled on me now it wont start i checked and there is still a spark going to the spark plugs. I also to the carbarator top off and everything looks good its still spinning it is not loose. I sprayed...
try taking of the air intake and spray carb cleaner into it and then try to start.
if it tries to start and then dies then your having a fuel issue.
that may be the fuel pump.
remove the back seat, put the key in the second position right before turning it over and listen for the fuel pump to start up.
if you dont hear anything then your fuel pump is bad or not getting power.
and then i would check the fuel pump relay switch first before replacing the pump.
hope this helps
Aug 06, 2011 | 1998 Honda Accord
2004 ford taurus hesitates when I hit the gas?
this is happening because of your fuel pressure which is slowing down when you open the throttle to the intake manifold. you are losing fuel pressure somewhere from the gas tank and the fuel rail. do a fuel pressure check test. that might do the trick.
Jul 26, 2009 | 2004 Ford Taurus
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Dayton E50 Heater Logo
588 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
