Question about iLO 2600 Television
Screen flashes red,blue,green ,white sound ok
Screen flashes red,green,blue,white sound ok
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, if the unit referred to is an iLO 2600 TV unit, then a temporary workaround may be applied by increasing the distance of the rear of the unit from the wall. The idea is to improve/increase the ventilation. The best would be to add forced ventilation such as the installation of blower/fans similar to those used in desktop computers.
Identified faults are in the air vents of the unit and that basically the unit runs hot.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 4,806 Answers
If "The right half has a picture the left has coloured lines.", than that is not a setting problem, that means that the TV has a fault.
If the image is also dimmer than normal, then it is for sure the Sus board that has a blown fuse and must be replaced (fuse indicates board is defective).
If you get vertical band on a portion of the screen this can also be because of one of the ribbon cables that connect to the screen.
This cables have a built in chip technology, and when the chip is fried you get vertical bands starting from where the cable hooks up.
To find out the technician must remove the metal bracket and cable from the connector and read impedance on the resistors located on the cable.
On many models there is also a board called lower buffer , when that goes faulty you also get a verical band , or part of the screen black, or covered in lines, depending on the fault.
regards
    Genius:
  • 1,239 Answers
Hi.welcome to fixya
repalce the main board and updated firmware to the latest. it is the red/green snow is a fairly common problem with the early units.after doing this Picture is fine now but we will see how long the fix lasts. Main board was definitely the issue, firmware upgrade was prob just because they could.
  • ABHISHEK.C
    ABHISHEK.C Dec 08, 2008
    Are they spaced evenly?
    If so, an IC responsible for control of the individual pixels has failed.
    If not - well, I can't think of anything that would cause a random appearance of any color.
  • 2,326 Answers
The color flashes could be cause by a low 5 volts from the power supply to the video circuit. If you are able to measure voltages using a multimeter, I would suggest to check for proper voltages, specially the 5 volts. If they are low then you have a power supply that might fail completely soon.
If your TV is less then a year old, I would suggest to contact the manufacturers to get fix under warranty.
Let me know if you need further assistance.
    Sergeant:
  • 399 Answers
Main board problem.any of the electric components gone loosed or faulty.check out the board to get the faulty ones replaced.
  • masterexpert Dec 08, 2008
    Depending which cables you are using, you should check your cables to see if you have them in the right order. The other issue with some ILO's they run really hot.  Keep the TV away from the wall and allow air flow.  If necessary, you may want to buy computer fans and mount them on top of the vents with air flowing outbound. (Using Coarse Thread Drywall Screws to mount-top two holes only) You will need to buy a universal adapter set to 12V. It will take some rigging with wires. (Red for  positive and black for ground) Test the fans before mounting. The fans run independently. Also, you will need a switch to turn off the fans when TV is not in use.  The problem with some models of ILO's , there are not enough vents for the heat build up. and it leads this problems.  so where ever it's hottest on the back panel, place the exhaust fan there. On bigger screens you may want 2-3 exhaust fans.  It is a $25-30.00 investment but your TV will last a lot longer...years
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
