Question about KitchenAid KGRS205TSS Stainless Steel Dual Fuel Range
Can't find a part for LP - KitchenAid KGRS205TSS Stainless Steel Dual Fuel Range
  • rugg85 Dec 08, 2008
    NO. According to the manual, I need an M57 broiler orifice. All I am trying to do is find that part. This is not rocket science. It's locating a part that's in my range's installation manual.
    Thanks.
    Habit-Forming:
  • 171 Answers
What you need is a presure regulator,that part goes as the flex line comes from the house line to the stove. between the flex line and the pipe of the stove. thats where you conect the regulator for propane.
Posted on Dec 08, 2008
  • i have the needles that can be put in side the orifice so that when you tight the orifice it will make the flame go down. go to any stove re pear shop near you to get that needle. or the orifice. bring the one that you have so that it can be match.
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
I like to conver my american range v. Broiler. Giro infrared burner to lp gas
that simple, all you can do it go to place where you can buy a LP orfice and LP regulator and remove all NG orfice and regulator out and install all LP orfice and regulator you ready to go for LP..
Jun 15, 2011 | American Range Ovens
Brand new roper dryer MOD RGD4440VQ1, Its gas and has a LP fitting how to change the LP fitting to PRopane. I have the conversion kit but can't find out how to install it
According to the roper site you may not change to LP gas yourself. You will need to get a licensed LP technician to make the conversion. The reason why is that they will need to adjust the flow of the Lp so that the dryer will work right. If you do not get a Lp technician to do the work then you will for fit the warranty on the Dryer.
May 28, 2011 | Roper Dryers
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Apr 28, 2011 | Heating & Cooling
For my mode should it be hp or lp
hp they provide lp, lp is tust an lp.... so your mode should be lp
Feb 23, 2010 | Alpine MRD-M1000 Car Audio Amplifier
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
What is the answer to puzzel 5, 18, 23, 27, 28, 36, 37, 38, 41, 112. In professor Layton and the curious village.
Puzzle 5 -- Answer is Ten Times 10
Puzzle 18 -- Move Top far Right Match to Left of the Dust-- Move Middle Match slightly Left to make the Handle.
Puzzle 23-- Empty 8 (Litre Pitcher) into 5 (L.P) Empty 5 (L.P) into
3(L.P) then empty 3 (LP) into 8 (L.P) then 5 (L.P) into
3(L.P) then 8(L.P) into 5 then 5 (L.P) into 3.(Litre P.)
Pour contents from the 3 (L.Pitcher) into 8(L.P) You
will have 4 Litres in two of the Pitchers.
Puzzle 27 -- Bickering Brothers -- Sit them clockwise from the top
as follows -- 1-- 3-- 6 -- 4 -- 2-- 5 -- .
Puzzle 28-- Find the Dot. Bottom Point on the Right.
Puzzle 36-- Only 1 as the mouse you bought was a MALE
Puzzle 37-- Brother & Sister-- They were Twins Age--- 6 (SIX)
Puzzles 38 - 41 -112-- are all quite easy, just play around you will get the Answers.
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Aug 17, 2008 | Canon ES8400V Camcorder
KitchenAid KGRS205TSS  Stainless Steel Dual Fuel  Range Logo
77 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
