Question about Technics SA-AX730 Receiver
Volume not working on remote
For quite some time now the volume doesnt work on my remote. At first the volume up stopped completely and volume down worked intermittently but now neither work. Is this a receiver problem or remote problem? I also have a Kenwood receiver which remote did not work but turned out to be problem with receiver. Thanks in advance for any advice.
Just get a universal remote like i did but i also had another technics remote from another unit.
Posted on Oct 01, 2007
My audio remote control stopped working on only the volume. It works to power the receiver up or off, etc., and the volume control works perfect when operated by hand, but no longer with remote.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Sep 26, 2016 | Universal Televison & Video
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Dec 12, 2012 | Sharp 32U-S610 32" TV
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
Replaced bulb on PT50LC13 5 months ago. Now a box pops up when I turn the tv on saying to reset the timer. How?
1. MAKE SURE POWER CORD IS PLUGGED IN.
2. WHILE PRESSING THE VOLUME BUTTON ON THE PROJECTION DISPLAY,HOLD DOWN PIP0R SPLIT BUTTON ON THE REMOTE CONTROL AT THE SAME TIME FOR MORE THAN 5 SECONDS.
3. WHEN THE RESET IS COMPLETE, THE SCREEN ON THE RIGHT WILL APPEAR AND IT SHOULD SAY "LAMP TIME RESET TO "0"
Jun 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 25, 2009 | Samsung HL-S5086W 50" HDTV
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Audio
Go to START, PROGRAMS, ACCESSORIES, ENTERTAINMENT, Volume control. With the volume control open, see if the volume is muted (Checkbox marked mute at bottom of Master volume) If it is checked, uncheck it, and you should have sound.
May 16, 2008 | Computers & Internet
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Technics SA-AX730 Receiver Logo
751 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
