Question about HP Pavilion zd8000 Notebook
Sound comming from laptop
Hi All I have a HP Pavillion laptop.There is a buzzing/whistling sound comming from inside. -when the power is plugged in there is a different sound than when it is running on a battery.(buzzing) -when in IE and the screen is not moving there is a whistle sound and as soon as the screen is scrolled up or down the sounds stop until the screen stops moving and it starts again. Any ideas what I can do?
  • Andre Visser Feb 26, 2007
    I now this cant be true, but it really sounds if the noise comes from the RAM or the Ram port. ANy suggestions?
Hi, I have to HP Pavilion zd8000 as well, and have exactly the same problem when using a jack to phono lead to my amplifier. I can't seem to figure it out, the only think I can think of is that it only makes this static interference noise when it's plug into the mains, so could it be the actual mains power supply that is faulty. May be the ferrite filters are damaged, or? not working as much as they should be? I'm going to try and get and new power supply and try it then, I'll keep you posted! Tim
Posted on May 24, 2007
  • 944 Answers
Sounds like a power supply fan problem - these can be easily and fairly cheaply replaced - it does not need much experience or skill to do this, but in order to purchase a new one you probably have to go to a repair shop anyway, so for a few bucks you can probably get them to replace it anyway. If you want to check it yourself, establish first of all if you can open the case, then listen to each fan individually (being careful not to touch anything at all inside) hopefully identifying which fan is the noisy one. If you feel competent to remove and replace this yourself then ensure the power is off and that you have adequately grounded yourself before touching anything inside, remove the offending fan and find a pc supplier who can get you a replacement. If you just want a quick fix - usually only lasts about a week - then some PTFE (teflon) spray can sometimes help noisy fans, but truly when they are on their way out they need replacing.
Posted on Feb 23, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Feb 26, 2007
    Sorry last solution no help, here is the link for the service, maintenance and troubleshooting manual for the zd8000
    http://h10032.www1.hp.com/ctg/Manual/c00...
    Couldn't find anything myself with the info you have given, but maybe you could spot something - please let me know if you need a hand with this - unfortunately have not been able to find the same model locally to have a look at it myself.
    only thought i've had is could it be faulty modem or modem driver/setup? possibly could funnel the sound out through the chassis to the ram area or gets resonance (unlikely). Sorry best I have at the moment. :)
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Jan 22, 2010 | HP Pavilion dv1000 Notebook
My laptop speaker won't stop buzzing. It began
A buzzing/humm sound could be a earth loop problem. This is caused by connecting amp equipment into different mains power outlets.
Use a power board and connect all your amps and laptop to the one power board.
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Hi, the problem is that when the HP Pavillion is switched on thereis a very loud beeping sound. One long and two short beep together. It renders the unit useless because it does not switch on for sometimes...
i think its an motherboard releted problem the beep sounds you told hear is produced by motherboard when it is facing any complaints in side it ask a certified HP technichian
Oct 19, 2009 | HP Pavilion dv9000z Notebook
Constant buzzing noise after warming up
uninstall the sound driver and reload. if this didnt work, reload the windows.
Aug 14, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Computer is making a buzzing sound. Is it the fan?
Your machine might be getting hot too early. Get it checked from the nearest service station.
Jul 11, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
No sound on hp pavillion 6000
Please download the audio driver for HP Pavilion zv6005us using the below link
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-29888-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=461824
May 04, 2009 | HP Pavilion zv6005us Notebook
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion zd8000 Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
