Question about Samsung SPH-M500 Cellular Phone
Problems with T9 predictive text Samsung SPH-m530
When using the T9 text message feature, the phone does not offer alternate words when the words are only 2 letters long. Eg: am and an, if and he,no and on etc Am I missing something?
Just starting to use this phone after using a Nokia.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 55 Answers
The phone is most likely got the setting only suggest alternate words after the 3rd letter inputted (unless i misunderstood the phone that setting's meaning)
Posted on Jan 11, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do i get predictive text. i cant work out how to do it.
The T9 feature is usually set in the settings menu under the "input method" tab. You can scroll through the options until you find it. According to the manual for your phone you can access it from the idle screen to the menu to: Phone settings→ Word suggestion: Set the phone to show the alternative word choices for your key presses in T9 mode.
the manual is available online at the link below.
http://www.o2.co.uk/deviceinfo/device-pdfs/samsungg600eng.pdf
Good luck to you
Oct 16, 2009 | Samsung SGH-G600 Cellular Phone
When I am writing a text message the phone starts predicting words. I just want to send a simple email without any ''help''
Hi!
If you are seeing the T9 icon on your screen, this is the T9 Text input feature of your phone. It act's like a built-in dictionary for commonly used in a sentence.
To disable this, while on writing mode, press and hold * key to disable text input.
Sep 25, 2009 | Sony Ericsson K850i Mobile Phone
Predictive text
you have to turn T9 off on your text message settings.
May 12, 2009 | Samsung SCH-u740 Cellular Phone
Predictive text
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Reset the T9 text dictionary
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Sep 25, 2008 | Samsung SGH-a737 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Predictive texting
I understand that u r unable to write message according to ur wish, Ur t9 dictionary is activated so pliz turn it off definitely u will  b able to type proper text.
Oct 21, 2007 | LG KG320 Cellular Phone
Texting while talking on phone
for 1 when in a call, hit the button right above the red END CALL button, the one that looks like 3 squares overlapping and the 2 arrows. scroll over to the messag option.
2. hit the '0/+' button
Sep 04, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SPH-M500 Cellular Phone Logo
233 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
