Question about Granite CamKiosk Gray Hand Sink Cart
Granite vanity top
Someone used a cleaner on the granite and it now has some spots that seem to have the gloss gone. Can it be repaired and how?
    Sergeant:
  • 359 Answers
If this is real granite ,check with a local monument or tombstone supplier in your area and ask if they will sell you a small amount of polishing compound , if this is not possible a regular grit toothpaste will work but will take way more rubbing , take a small amount on handkerchief use the tip of your finger rubbing a while then take dry rag such as small towel and buff , repeat until gloss is back or your finger is to sore to continue , tomorrow again . ps make sure it is granite and not plastic
Posted on Dec 09, 2008
MW 500 water heater electric glass lined in leaking 1+ cup of water daily and getting worse what if anything can I do to fix problem
: i would like to have a little more information,how old is this water heater? and does it leak at bottom? turn off the power,remove the to pannels which will reveil the upper or lower thermostat,you may have to push aside a little insulation first .if there is any wet up or down you probably have a leaky seal around the thermostat,and do all the conections on top HOT/COLD lines look ok,some times the hot water pressure valve valve can leak against the tank inside, if possible check arround the drain valve, have you ever changed the ANODE ROD inside the tank wich is made of MAGNESIUM wich over time desolves in the water whch help keep the minerals at bay,thay last about 2 years that depends on how hard your water is. When this ANODE is gone glass ligned or not your tank will rust uless replaced. one good suggestion ,if you are to change the tank and you are able to afford it get a STAINLESS STEEL HOT WATER BOILER and the heating elements inside are as well this should last for many years.sorry im not there to look for you .GOOD LUCK M.M.
Apr 22, 2018 | Water Water Heaters
Why is my hot water heater is using too much power?
It almost sounds as if someone is hooked into your electrical system check for outside cables or extensions cords going into a window or even at the fuse box
Sep 05, 2014 | Water Heaters
Fill tank& descale keep flashing.
Fill the reservoir with white vinegar and run a cycle. Discard the vinegar and repeat the process a second time. that should remove the scale and reset the flashing light.
May 19, 2014 | Bosch TAS2002GB Tassimo T20 Hot Beverage...
On a laurastar s4 water leaking from tank now the greenlight wont come on
the fault is with the PCB card which sits underneath the water tank, so any leak from the top could end up on the card causing to short. you can contact us on 0208 4419412 and we will help you. we are an electrical repair centre in Barnet specialising in repairing high end steam generators like yours
Air Purifiers Conditioners Humidifiers Steam Generators Steam Cleaners...
Feb 18, 2013 | Water Heaters
Hot water noise when tap is turned on louder when full on at tap. Atwood MOdel GC104A
Noise in pipe means vibration.
Pipes vibrate when water turns corner, or if there is a clog somewhere in the line, or if there is air in the line.
Water heaters make noise when sediment builds up inside of tank.
I would probably try to track location of noise, and then put that spot on top of suspect list. For example if sink has shut-off, and noise seems loudest there.
May 08, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
My tankless is leaking after a hard freeze this week. I called a plumber and he said that it would probably be best to just replace it with a new one because the cost of the parts and labor are going to...
Plumbers like quick easy money and dont comprehend ordering parts, they can buy everything they need down the street.I cant find any parts catalogs or parts suppliers online for this brand.Lowes did cary this brand but this model is discontinued.They may be able to help you find someone to repair the unit and I would be suprised if it as expensive as a new one.Also Sears services all brands of appliances and maybe they can help.Wish i could give you more.I have installed these kind on water heaters but have never repaired one.They seem to be trouble free.
Feb 16, 2011 | Noritz 6.3 Gallon Residential Tankless...
ADK-1 Super------------why is it that I have to relpace the unit or repair it at least 6 times in 9 months? I have replaced the plunger and spring along with the heat sensor each time and still they die....
If you live in an area where you have hard water it can destroy pretty much any tankless water heater, but it seems that you may have another problem, I speak to them on a regular basis and everyone there seems to speak English and Spanish, its very important to make sure that this unit is installed by a liscensed person, whom will check your wire gauge, and breaker size, if you use 240v this unit can draw upto 66 amps, so its important to have an electrician size your heater for the correct voltage.
Feb 02, 2011 | RTO American Heat Tankless Electric Water...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Bosch 16p gas, keeps going hot and cold
check the thermostat, you will probly need someone that has worked on the same kind of unit, they are not all the same {tankless} I would suggest a repairman,, there is a little bit much to explain how to do it over the internet,
Jun 22, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Hot water heater is leaking and making noise
Hit the disconnect and call a plumber. Sounds like your heating element or elements have gone bad and need to be replaced. also shut off the water. This is repairable, but it is HIGHLY recommened to have someone with expeirence in this kinda of problem fix it since you are messing with water and electricity. The repair should be no more then 200 dollars
Feb 10, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Granite CamKiosk  Gray Hand Sink Cart Logo
152 people viewed this question
Top Granite Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Granite Water Heater Expert? Answer questions, earn points and help others
