Question about E-Machines T5082 PC Desktop
Why won't drive d open?
Drive D on my emachine t5082 won't open. I wanted to back up my computer and it said to insert a disk in drive d but it won't open.
  • Anonymous Dec 08, 2008
    I went to My Computer and the D drive is listed as Recovery but I'm not able to click on it. Does this mean it is dead?
    Scholar:
  • 86 Answers
This is a common problem with old or poor quality DVD/CD players. Try going to My Computer, right clicking on the drive and selecting 'eject'. I this doesn't work then just replace the drive and all will be well. If the drive is not shown in My Computer then you must assume it is dead.
Posted on Dec 08, 2008
My emachines EL1850-01e Disc drive won't open, I've tried pressing the button and I can't find the eject button anywhere on my computer!
there is a small hole on or around the drawer . straighten a paper clip insert it in the hole to release the lock .
Feb 17, 2012 | E-Machines emachines (emachinees) CD-ROM...
Emachine disk door want open
I'm assuming the CD drive door is stuck and won't open. You will see a small hole in front of the drive. Take a pin and insert it in the hole and push it. The drive should open up.
May 05, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
Manaully open a disk player for a emachine
there's a small hole in the front of the disk drive close to the base of the tray and near the button used to open the drive. get a paper clip, open one end, hold carefully, and place it in the hole and push carefully till the drive opens.
to close, just push the tray back in firmly but without slaming it in. don't want to damage any of the gears inside.
Sep 24, 2009 | Computers & Internet
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Cannot load os
If you have your operating system disc. Then insert it in the cd drive and start up. You may have to change your BIOS to have it start from the CD drive. Allow your cd to run for a few minutes. Eventually it will stop and ask you if you want to load the operating system or if you want to repair it. Choose repair. That will fix your problem and allow you to get into Windows.
Don't forget to rate this solution.
Feb 04, 2009 | E-Machines T5082 PC Desktop
Restore back to factory setting
take any of vista disk(any copy)
boot with cd in repair option get restore click.
Jan 25, 2009 | E-Machines (T2958) PC Desktop
T5082 CF reader problem
If your comfortable opening the case, I would try disconnecting the reader from the mother board, and then reconnecting it. Sometime reseating the connections will fix it. Usually however the hardware is bad. If this is the case, you can get a replacement here
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=6082 IT's a little pricey though, may want to watch for the part number on Ebay.
Dec 31, 2008 | E-Machines eMachines Desktop PC
Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
Dec 14, 2008 | E-Machines T5082 PC Desktop
Cannot open the disk drive.
It happens when you stop using your drive
use pins and insert in small hole present above the LED[light]
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
Connecting to my E:\ drive
Hi fantisy, It's not uncommon for your DVD player to not have the drive letter you were expecting it to have. Let me show you. Place a CD or DVD in to your cdrom drive, close the drawl. Close any windows that may open Ok here we go. Right click once on the Start button, than slide up to & left click on Explorer. Take a look at the icons. Left click once on the - sign to the left of C:
The icon you see to the left of C: is a hard drive. Look down to your DVD drive, see the differance in the icon, (a cd on top of a hard drive icon). Your E-Machine also has a SD card reader. Each card slot also shows a hard drive icon. So drive D: is your DVD player & F, G, H & I are SD card reader drives. Windows just skipped letter E.
You can re-assign your drive letters through windows Computer Management. Type Computer Management in your help window. Under Overviews, Articles and Tutorials, is Using Computer Management. Clcik on it.In the right half of help click,
Open Computer Management (Local).
Once opened click Disk Management. Here is where you can re-assign drive letters.
( DO NOT ) change C: drive letter assignment.
Enjoy!
Mike
Mar 31, 2008 | E-Machines T5082 PC Desktop
E-Machines T5082 PC Desktop Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
