Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Stem Valve is frozen on my 3175 Legend.
I need to remove and replace the stem from my one handle Moen 3175 faucet. I tried pulling on it with pliers but it's stuck. The clip has been repoved.
  • Anonymous Mar 27, 2014
    Sku# 159944
  • 33 Answers
Here is a possible solution for you. First go out and buy a Moen cartridge puller tool like this:
Next follow these steps:
  1. Turn off the water to the valve.
  2. Install puller and rotate cartridge several times.
  3. Gently pull on cartridge while slowly turning.
This should work. If the center of the valve pulls out continue below with these suggestions:
  1. Remove center piece from tool.
  2. Place the brass feral to the end of the tool as shown.
  3. Insert this part of the tool into the valve all the way as far as it can go.
  4. Turn the tool until you hear a click or tool feels like it turns the valve.
  5. Pull on the tool gently while turning.
This should get the job done.
Also here is some information for you about your valve:
Moen 3175
Hope this helps and please rate this suggestion.
Posted on Dec 08, 2008
Very difficult to pull faucet handle out to turn on in shower installation
the cartridge heeds to be replaced. It sounds like you have a moen shower valve. turning the stem on this cartridge will only reverse hot and cold. it will not fix your problem.
Sep 01, 2011 | Moen 3175 Legend One Handle Shower Faucet...
How do you remove the cartridge?
Remove the handle by removing set screw on the bottom of the handle. The screw is located under plastic button with the red and blue marking on it. Pull handle off and remove the retaining clip that is in front of the cartridge. Do this by holding the tab on the top with needle nose pliers and pulling up. Be careful to not break it as the new cartridge does not come with one. Use a pair of pliers to grasp the handle stem and pull out to remove cartridge. If you need to you can buy a moen removal tool and follow instructions to use.They have some very good easy to follow videos on u-tube that will show you step by step direction on what you need to do and helpful tips to make it easier. They explain themselves much better then I can. Try my Thank you.
Aug 29, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
How do you turn off the moen 82691 shower valve when new.
The stem in faucet may be in faucet upside down . you can try taking handle off remove nut that holds stem take it out make sure
you turn water off before doing this.
May 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I am installing the valve housing for a moen shower. before placing the handle on the stem do I have to remove the cotter pin?
No...the (cotter pin) is a retaining piece for the cartridge. If you remove it the cartridge can blow out under pressure.
Apr 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Can't get the retaining ring back in on MOEN Magnum Replacement Cartridge
Make sure that the stem is slightly pulled out or open then use the plastic insertion tool that comes with the new cartridge and a pair of pliers to push cart. all the way in. Try the retaining clip again. If still won't go, partially install the insertion tool and turn cart. back and forth til clip goes in. Hope this helps
Nov 30, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
293 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
