Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Lights keep flashing
First two lights keep flashing together and it hasn't emptied
    Problem Solver:
Have you have checked the waste pipe is not kinked and raised to about level with the top of the machine? If you have checked these things it could be the waste pump located at the rear right corner in the base of the unit.
To acess the pump tilt the machine to 45degrees and remove the base plate(6 screws) remove the two wires from the float(brown and pink) and move the plate out of your way.In the rear right corner you will see the waste pump.remove the pump and check the impelor is turning freely.If not dissmantle the pump(3 screws)and carefully remove any debris.Re-assemble.good luck.
Posted on Dec 26, 2008
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
The yellow ink light keeps flashing on my HP5150 printer, I have just installed new cartridges and have tried cleaning the sensors but that hasn't worked
If the old cartridge also give that alarm so ignore it and keep working..it's a sensor malfunction
but if the old one is not giving that alarm, i think its compatibility problem or the new cartridge is not original.
Aug 24, 2011 | HP DeskJet 5150 InkJet Printer
I have a ford ranger 2.5 4x4 of 2007. The diff lock light keeps flashing while driving.
When the light flashes it usually means it is set to engage, but hasn't done so yet. I would checking the wiring and piping at the differentials...one might have come loose.
Jul 28, 2011 | 2007 Ford Ranger FX4 Off-Road
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
May 31, 2009 | Gaggia Syncrony Compact Coffee...
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Light Keeps Flashing
Hi pmerriwether
One of your cartridges have a problem (is empty)
If you have replaced the black cartridge and still get the error replace the color cartridge aswell.
Regards
Go-Tech
Aug 06, 2008 | HP DeskJet 694c InkJet Printer
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
293 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
