I put new ddr3 2gb memory anew vidieo card eva 8400gs but won't boot up or display on monitor i cleared the board i believe
Add one item at a time.
First memory, then graphics card.
Plus you cleared CMOS Error Codes, and set the BIOS Setup parameters back to the factory default settings.
Guess what the default graphics setting is for an MSI G41ME43 motherboard?
Yep, AGP.
http://www.msi.com/product/mb/G41M-E43.html
[Wow, I like MFlash, and the solid Polymer capacitors.
Live BIOS Update 5, and Easy OC Switch.
However if the motherboard fails, I'll bet the Integrated Circuit, (I.C., or 'chipset'), that controls APS, is the first electronic component to go.
I would also watch OC'ing. Has to be done in incremental steps. Automatic feature or not. A 20 percent boost is A LOT.
Hardware components have as tendency to heat up.
Watch it as this lowers the 'life expectancy' of the chips.
Heat - 'Kills' ]
http://www.msi.com/product/mb/G41M-E43.html#/?div=Detail
Motherboard chipset:
Northbridge is an Intel 82G43. Southbridge chip is an Intel 82801GB part number. (ICH7) You can't see them as they are under Heatsinks.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets
Ram Memory:
Two ram memory slots for Dual Inline Memory Modules on the motherboard. (DIMM)
A) UNBUFFERED
B) 1.5 Volt (DC)
C) DDR3 Sdram at either 800MegaHertz, or 1066MHz.
[ This puzzled me. DDR3 Sdram at 800MegaHertz?
Why would anyone want to use DDR3 Sdram at 800MegaHertz?
Seems to me going backwards.
Faster frequency rates.
Low end for DDR3? 1066MHz.
High end for DDR2? 800MHz.
DDR3 is faster in comparison to DDR2 per se, because of the prefetch buffer. 8 burst deep compared to DDR2's 4 burst deep.
(Or DDR's 2 burst deep)
Not because of the CAS Latency, though.
DDR3 has a much higher CL, than compared to DDR2.
(Average CL for DDR3 at 1066MHz = 7-7-7-20
DDR2 = 5-5-5-15. Note* -> A-V-E-R-A-G-E. )
When using DDR3 Sdram at least use 1066MHz, IMHO
The maximum ram memory frequency rate, that your motherboard will support ]
So what manufacturer of ram memory is it, and what is the manufacturer code of the ram memory module/s? ('Stick')
JEDEC sets the standards for Ram Memory.
Voltage standard for DDR3 Sdram ram memory is 1.5 Volts (DC)
So the factory default setting is 1.5 Volts, for the motherboard.
However your motherboard supports SPD.
(Serial Presence Detect,
http://en.wikipedia.org/wiki/Serial_presence_detect )
Point of the above?
If you are trying to use high-performance ram memory; say one needing a slightly higher voltage, and/or has lower CL ratings; then the SPD on the motherboard may make automatic adjustments.
(Adjustments to the parameters in your BIOS Setup)
May take 2 to 3 'Cold Boots', though.
(Turn the computer all the way off. Wait 1 minute. Turn the computer back on = Cold Boot)
I order for SPD to work, BOTH the motherboard, AND the ram memory, have to have SPD feature.
If the ram memory is too low in quality, (Read cheap), it may not have SPD.
Means you have to go into BIOS Setup, and set the ram memory parameters, manually.
[ Delete key to enter BIOS Setup.
Main BIOS Setup menu > Cell Menu > Memory Z > Advance DRAM configuration >
1) DRAM Timing Mode
2) CAS Latency
3) tRCD
4) tRP
5) tRAS
6) tRTP
Don't forget you have to SAVE changes, or it will be as if you have done nothing at all.
If a mistake is made;
Go back to BIOS Setup, and in the Main menu, use the Down Arrow key to arrive at Load Fail-Safe Defaults. IF -> OK is 'highlighted' (Black surround) press the Enter key. If not, use the Right Arrow key, or Left Arrow key, and highlight OK ]
The ram memory also has to be UNBUFFERED.
Unbuffered ram memory is the opposite of Registered ram memory.
Registered ram memory is more stable, usually one clock slower, and more expensive, than compared to unbuffered ram memory.
Registered ram memory is usually used in SERVER computers.
(A Server computer may look at information 2 or 3 times, before it acts on it. It needs to be C-O-R-R-E-C-T for a server computer )
"Cleared the board i believe"
Turned the computer off? Unplugged from power? Pressed the Power ON button in, and held it in for a count of 10 seconds? Then let go of the Power On button, then performed the entire procedure again, 2 more times?
{Clears CMOS Error Codes, and resets BIOS Setup back to the factory default settings}
You MAY have cleared the motherboard. It's what I use, and have recommended for years on the 'net. Doesn't mean it always works, though. Sometimes you just have to go into BIOS Setup, and set the parameters back to the factory default settings.
(For you? Load Fail-Safe Defaults )
A) Won't boot:
Because the ram memory is the wrong one, (Or ones); OR, the ram memory is high performance, and BIOS and SPD hasn't recognized it yet.
Remove the graphics card.(Computer unplugged from power. Anti-Static Precautions FOLLOWED!)
Remove the ram memory.
Reinstall the old ram memory, and plug the monitor into the VGA port, in the I/O area on the back of the computer tower.
Just get the computer working again. After about 10 minutes of fooling around on the computer, ('net?), turn the computer off.
Install the new 2GB.
(IF, just one ram memory module, be SURE to put it in Slot 1.
{DIMM 1} The ram memory slot closest to the Processor )
Leave the computer case open. You may be going back in pretty soon. (Graphics card)
WAIT 1 minute, then turn the computer on.
Joy?
If no joy shut the computer down. (Press the Power On button in, and hold it in for a count of 10 seconds)
WAIT 1 minute, turn the computer on.
If it doesn't work this time, you may wish to try it again.
Sometimes takes 2 to 3 times, before the high-performance ram memory is recognized.
You can also go into BIOS Setup, as mentioned, and physically set the ram parameters.
After 3 times I would give up however, and send the ram memory back. Wrong one/s.
If you get the new Ram Memory working, Cool!
If not remove it, and use the old ram memory.
Might as well get the computer going with the new graphics card, while you wait on the proper ram memory to arrive.
Did you plug the monitor into the graphics card?
Sometimes we computer geeks get in a wee bit of a hurry, when we get shiny new parts. Make sure the monitor cable is plugged into the graphics card.
There is another tiny thing; DRIVERS
If you did not use the Installation Disk (CD) first, THEN physically installed the graphics card, you are Wrong.
OR downloaded the drivers from EVGA.
What happens if you physically install a graphics card, THEN come back and install the drivers?
Most of the time a Driver Conflict.
Windows: "Which drivers do I use? These or THESE?"
Also sets BIOS Setup to the correct graphics aperture.
With the computer set back to the factory default settings, and the monitor plugged into the VGA port on the motherboard, you can get Windows running, and install, or download AND install, the Drivers.
ONCE the drivers, (And user interface -> Nvidia Control Panel), have been installed, you can then physically install the graphics card.
[Again; If you download the drivers, do NOT forget you have to go to where they are downloaded, and DOUBLE-click on the file, then use the Installation Wizard. (Or double-click on the .exe file)
INSTALL them! ]
Drivers installed, close all windows, go back to your desktop screen.
Turn the computer off. Unplug from power. FOLLOW Anti-Static Precautions. Physically install the graphics card. Plug the monitor into the graphics card. Plug the computer back into power. WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
SOURCE: MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
SOURCE: Ram upgrade issue msi 845 pro motherboard
you should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
hope this helps
