Question about Independent Inc. Low Profile Heat Lamp Seamed Construction Wall Model - LPHL- Kitchen Hood
Bathroom heat lamp stopped working.
The heat lamp in our bathroom won't turn on, after working reliably for about 3 years - the bulb works in other lighting fixtures so is not a bulb problem and all the bathroom fans and lights go on too, no obvious issues with the power panel or supply... any ideas what could be wrong?
Lamp, fan and lights are all on seprate switches in this bathroom.
Thanks a lot in advance for any advice you can offer.
Rick
Thermostat on the fixture is busted
Posted on Feb 19, 2009
HAVE YOU EVER HEARD OF A BULB THAT CAN LAST UP TO 35 YEARS?
Every home needs good lighting that's energy-efficient and attractive. Good lighting is essential in any home, and it all starts with the humble light bulb.
In comparison to traditional lighting bulbs which release 90% of their energy as heat LED bulbs emit very little.
Many organizations around the world have tested and compared LED-based solutions for municipal and commercial exterior lighting applications, such as LED roadway lighting, LED Street Lights, outdoor LED flood lights and LED shop lighting. The results consistently show the following:
1. Save up to 75% on your light bill.
2. 155,000 hours, or a 30 year bulb life (based on proven LM-80, LM79 and TM-21 Data).
3. features include 141 lm/W LED output, >115 lm/W Fixture.
4. Solid-State Technology delivers hurricane and vibration protection.
5. All products are fully certified & approved.
I have some more knowledge about home energy audit and Off Grid Solar Systems.
Dec 13, 2017 | Televison & Video
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Light Switch delays coming on
it sounds as if you have a fluorescent bulb and they work with a transformer or ballast. sometimes is less expensive to replace fixture.
Jan 16, 2014 | Electrical Supplies
03 Chevy Trailblazer left rear taillight will not work. Brake light, back up light & turn signal all work. Right rear all work. Replaced bulbs, switched sides, still nothing.
There was a recall on this, see your local Chevrolet dealer.... Recall Date: NOV 01, 2004 Model Affected: 2003 Chevrolet Trailblazer Summary: ON CERTAIN SPORT UTILITY VEHICLES, VIBRATION AND HEAT MAY CAUSE THE TAIL LAMP/STOP LAMP BULB TO LOOSEN IN ITS SOCKET. IF THIS OCCURS, THE BULB MAY FLICKER AND EVENTUALLY BECOME INOPERATIVE. Consequences: AN INOPERATIVE BRAKE LAMP WILL NOT CONVEY THE DRIVER'S INTENTION OF STOPPING TO DRIVERS IN FOLLOWING VEHICLES, AND AN INOPERATIVE REAR TURN SIGNAL LAMP WILL NOT CONVEY THE DRIVER'S INTENTION TO TURN TO DRIVERS IN FOLLOWING VEHICLES. BOTH OF THESE FAILURES CAN INCREASE THE RISK OF A CRASH. Remedy: DEALERS WILL INSPECT THE TAIL LAMP/STOP LAMP ASSEMBLIES, AND IF NECESSARY, REPLACE THEM. THE RECALL BEGAN ON NOVEMBER 22, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, OLDSMOBILE AT 1-800-630-6537, BUICK AT 1-866-608-8080, OR GMC AT 1-866-996-9463. Potential Units Affected: 871473 Notes: GENERAL MOTORS CORP. Read more: http://www.motortrend.com/cars/2003/chevrolet/trailblazer/recalls/#ixzz2jWJ1eDyR
Nov 02, 2013 | Cars & Trucks
Horn doesn't work, revrese lights won't come on, and 2 of the 3 break lights won't come on on 1995 Geo Tracker. Fuses are good and bulbs are good.
for how long, 1 day, 1 year , 1 decade? is it a daily driver
or a barn stored, winter car.?
the real question,is there 12v exiting the fuse, the acid test. that.
any volt meter does that in 5min flat.
3rd brake light is bad bulb or corroded socket.
what tranny< 3,4,5,sp.? but in each case it takes a good rev.
switch, if 12v enters said switch and does not exit, its bad.
0v bad,6v rev. path shorted to ground,12v good.
btw, all clamps can short, try 1 new one. in each path all by lonesome. dig?
bulbs good means what.
1: look good.
2: glow when placed on a 12v battery
3:measure 0 ohms with meter (means good or shorted.
4: or they are new and assumed good, (p/n ? what is the p/n?)
head lamps good.? parking lamps, blinker, are all other lamps working. does car start?
Dec 05, 2012 | 1995 Geo Tracker
Problems replacing a 2D 4 pin holder fluorescent bathroom light.
I'm sure they made it that way for a reason. Unless you know the specifications will match, don't try to jerry-rig it to fit.
May 07, 2017 | Electrical Supplies
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Bathroom fixture- bulbs are not burned out but fixture will not turn on. Periodically it will turn on. I haven't tried to fix it yet. Since it is electrical I didn't want to attempt anything unless I...
sounds like a loose connection. You will need to take fixture down and check to see if the wire nuts are tight. Make sure power is off. Also, check to make sure the sockets are tight where the bulbs screw in. Hope this helps Tim
Nov 27, 2010 | Home
Kitchen Ranges Logo
775 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
