Question about Hotpoint Dryers
Hotpoint tc11 tumble dryer no heat
Spins o.k but not getting warm
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Posted on Feb 17, 2009
SOURCE: hotpoint tumble dryer tdl31p
i have a 2nd hand hotpoint aquarius Autodry Model tdl31 tumble drier. I need an instruction manual. Can anyone help with emailing me one?
Posted on Aug 11, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Posted on Sep 23, 2009
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
The tumble dryer on my hotpoint WDL 540 is not getting warm. I assume it's the heating element, but would be grateful for advice if it could be anything else or how easy it is to fit a new...
hello i'd check the heat sensors first there may be 2 of them you will need a multimeter to test them if 1 is faulty change both of them hope it helps
regards
shaun
Mar 11, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
Hotpoint dryer not heating, dryer tumbles but no heat.
check the switch is working then go to the heating coils and check there working ok the next thing to go to is the heat censor inside above the door if this is not working you wont get any heats at all,
Jul 01, 2010 | Hotpoint Dryers
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
