Question about RCA F27242GY 27" TV
It died... I was watching my TV a couple of nights ago and suddenly it popped quietly and went off. I unplugged it and pulled the back off,found the fuse and replaced it with the only other one I had,which is a 4 amp,and cleaned the dust out of the works gently with a vacuum,replaced the back and plugged it in,but when I did it sparked at the plug and blew the fuse again. Any idea why it'd do this? This set has been trouble free since I got it new,until this happened. Where I had it,nothing could disturb the cord or plug,and nothing different was going on that might have caused a problem.(No lightning or power fluctuation) When I plugged it in the second time,it was at a different outlet than before,so I'm ruling that out.I use a remote to turn it on and off,but wasn't touching the remote when it died,and had been watching the set for about an hour. The TV showed no signs of trouble before it quit working. Thanks for your attention! James
  • 944 Answers
If the fuse you replaced is a different rating to the one that was originally in your set then go out and get the correct fuse (get a couple)and try that. If you still have no joy then the most likely problem will be a failed transformer in the power supply - sometimes you may be able to see burnt areas on the surface of the transformer windings although these do not always indicate a problem. a short in the transformer can be fixed in many cases, but the most economical way to repair this type of problem is to replace the transformer with the correct type (usually readily available from electronics/TV repair shops. The fact that you say it sparked at the plug is a little unusual, and could indicate a problem solely in the plug and power cord itself, easily replaced if you want to verify this. If you are competent to use a multimeter then a quick continuity test on the power cord would soon tell you if the short is in the supply cable/plug itself.
Posted on Feb 23, 2007
Watching TV and all of a sudden a loud pop came from the back of the set. Doesn't turn back on after unplugging.
Hello
Check its power supply regulator board. The pop sound you heard may be due to an explosion to any electrolytic capcitors on it. If the line voltage exceeds, this fault will happen. just repalce the damaged component. It is best to replace this board as card basis.
Mar 19, 2012 | Hitachi 50HDA39 50 in. Plasma HDTV
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Apr 11, 2009 | Dynex DX-LCD37 TV
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power problem
Check out ebay for the part.
My 3 year Sceptre 27" died. Local TV tech said it was the power module. Charged $25 for the diagnosis and wanted $190 to fix it. Took it home, popped the screws and the module almost fell out. It's a simple plug'n'play!!! Found a new module on eBay for $65 shipping included.
Jun 03, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
RCA F27242GY 27" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
