Question about Canon PowerShot A75 Digital Camera
Powershot A75- zoom doesn't work/ always says change batteries
Hi, My Cannon Powershot A75 turns on fine, but it won't zoom and then it says that I need to change my batteries. I am wondering if that is because I am using Italian AA batteries, because I am studying in Italy? I have no idea, is there anything I can do or should I just try to take it to a repair shop? Thanks!
  • 944 Answers
It is very unlikely to be a problem with the batteries if you are sure they are new and the right size and correctly inserted. The fact that it turns on at all would indicate that the batteries are fine. A "stuck" zoom on this range of cameras is often solved by giving the camera a gentle slap. (I have an A95 which had a similar problem that solved itself when my girlfriend dropped it). I wouldn't recommend dropping your camera, but try a little soft violence and you may find it works. If not, then a repair shop is definitely the best solution as these cameras have few internal parts that an amateur could fix. Possibly another solution could be to try the external power supply - most main camera shops should be able to supply - thus eliminating completely the possibility of the batteries being the problem, but it sounds like a mechanical issue with the zoom mechanism.
Posted on Feb 23, 2007
SOURCE:
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Whats a good memory card for the cannon powershot A410
You can use any MMC or SD card. Be careful not to get SDHC or SDXC cards, they won't work in the A410. The brand doesn't matter, though I'd stick with the major brands, like Lexar, PNY, and SanDisk. The speed doesn't matter much either, so I wouldn't waste money on fast cards.
Aug 29, 2011 | Canon PowerShot A410 Digital Camera
Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
Camera won't turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 19, 2009 | Canon PowerShot A75 Digital Camera
Cannon Powershot A720 IS, wont turn on.
Where do you live? Look up Canon on your computer and find out where they are located. The nearest one to you.
Jun 09, 2017 | Canon PowerShot A720 IS Digital Camera
Cannon software
Check few software updates available at Canon Support for A75 camera might solve your problem.
Oct 22, 2008 | Canon PowerShot S1 IS Digital Camera
Camera just froze up.
Try Rebooting the camera. Take out the existing batteries and insert some new ones. Then, turn it on and the lens should go back inside!
Hope this helps.
Jan 29, 2008 | Canon PowerShot A75 Digital Camera
Canon powershot A75 -cannot focus and image not clear
This sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras1.gif include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS2.gif V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 10, 2007 | Canon PowerShot A75 Digital Camera
Taking video clips
hi, It should not problem with flash card but while you placed it some setting must have changed Sangita
Jun 23, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
