Question about Microwave Ovens
Panasonic microwave (model NN-P295) power failure
Hi:
Our ''young'' (2+ year old) Panasonic NN-P295 microwave is totally dead now:
it happened when the night light was turned on: it immediately burned out with a bright flash and now the whole microwave is dead. (AC outlet still working good: I checked that).
Any ideas on what to check? (This is actually my mom's: I am going to go over soon and see if it has any fuses, and I can bring my voltmeter too to do some basic checks).
Thanks in advance for any input.
Panasonic CQ-C1313NE
Posted on Feb 17, 2010
  • Microwave Ovens Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
If it's really bad, we will have to also replace the microprocessor, which will add $15 to the cost.
If we don't have the parts yours need in stock, it will take about 4 weeks or so to get them. Even though we order from a top-tier distributor, they have to order them from Panasonic Japan.
I stock microprocessor # MN101C54CEN.
You can look at your microprocessor to see what number is on it, and to look for a bump or other odd spot that would tell you it's been zapped, as in the photo below
We have one board in stock, part number F603L5V30AP for $50. If it fits your model, that may be the quickest / best solution for you.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2008
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Mw oven totally dead. 2 year old panasonic
No sorry there is none... look what usually happens is the magnetron, or high power diode, or Oower Supply goes faulty, a magnetron can cost between $95 - $150, or more...and usually that is NOT the only part that will/would need replacing. Cut your losses, and get a firm "Quote" from a repair center, or get a new one, with a 5 year Warranty.
Mar 03, 2010 | Microwave Ovens
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
Panasonic NN-P295 Cooktop Light not working
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
William E. Miller
prototech@usa.net
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
New Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Aug 24, 2008 | Panasonic NN-P295SF Microwave Oven
Pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-P294SF Microwave Oven
Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Oct 25, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
1,135 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
