Question about Zenith TVBR1322 13 in. Combo
Timer record set
I used timer record set in menu for recording a program, but the set timer was never on so that the program was never recorded. i don't know why it is not working. I really want to record some shows, but I can't. Please help me...
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Posted on Jun 25, 2007
How do you delete a program that is mistakenly added to the record every episode mode
The easiest way I know is to press menu, then daily schedule. Find the program in question in your list. Click on that program and you will se a window "timers", click on that and you will see "delete", click on that. then you can reset your program to record the way you want. You can also follow the same proceedure, click menu, then daily schedule, then click on "timers". Scroll to the timer you want to delete, click on it, then click on delete.
May 02, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Zenith TVBR1322 13 in. Combo Logo
117 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
