Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Grinder does not work
The grinder does not work. Everything else does?
  • 8,596 Answers
Clean the grind chute out underneath the grind chamber.
Posted on Dec 30, 2008
What is the best meat grinder in 2018?
I used to make ground meat and sausage by myself. So meat grinder is a must-have for me. Normally I use KitchenAid meat grinder attachments. It's multifunctional but I need something more portable sometimes. Finally, I got this grinder. Now I can do my job anywhere in the kitchen. Believe me, you won't want to move a stand mixer frequently. This unit is solid. The motor is very powerful and works like a charm. 5 lbs ground meat is done in minutes. Normally I froze meats for 2 hours before grinding. That helps a lot. There is 3 size grinding discs for different needs. The medium is the one I like the most. It also comes with sausage attachments. Everything I need is included. I have nothing to complain, great buy.Click here for more info Best Meat Grinder In 2018 Quick Look At The Best Meat Grinders
Mar 11, 2018 | The Kitchen Appliances - Others
Grinder is not working. Makes a clicking sound
There is probably a stone jamming the grinding teeth. You need to take the top off the grinder and pick/vacuum everything out of in the grinding department. The top of the grinder has the stationary grinding teeth attached to it.
Oct 08, 2015 | Krups Coffee Makers & Espresso Machines
Grinder problem
try to check the brew group
Jun 18, 2012 | Saeco Odea Giro Plus Coffee Maker
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
May 10, 2012 | Saeco Caffe Charisma Espresso Machine
Saeco Primea Cappuccino must be reset I recive error mesage : error 1 I replaced grinder with a new one but the error message remained on screen and do not know how to reset
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
Oct 08, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Grinder doesnt grind beans although the motor works and the burr spins. I have cleaned it per the instructions and reassembled . Everything seems to fit together properly, but the beans don't seem to be...
I would suspect a log in the outlet shute where it goes into the grinds hopper. Clean it out and then turn the hopper to the coarsest setting to clean it out all together. Coarse grinds are a very good cleaner.
Oct 03, 2010 | Solis Maestro Electric Burr Grinder
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
190 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
